Help with Manchester decoding
I am looking for some help decoding a Manchester signal into binary using the prop. The signal is 64 bits with 1 start and 1 stop bit (total of 66 bits)
Signal specs are:
280uS / 3.57KHzPeriods
Signal specs are:
http://www.eetasia.com/STATIC/PDF/200805/EEOL_2008MAY23_EMS_AN_03.pdf?SOURCES=DOWNLOAD
Thanks for the reply. I have worked with manchester decoding before, however I am a Spin virgin and this was perhaps a little much to take on as a "first" project with the prop. I have found lots of theory on these forums regarding bi-phase , but yet to discover any actual spin code.
I have been tweaking counter code from some of the IR remote, RC receiver objects as well as any other place I could highjack some code from. My "swap and plop" method of coding in Spin is leaving me guessing at allot of things and its going to take some time.
I have taken some of JohnyMac's code from his Pulse Measure object and manipulated it to the point where I am able to measure values that have some distant relation to the data that I see on my scope. However I know the timing is off and I am having a hard time figuring out what the first bit the Prop sees is, in relation to what the first bit sent actually was. For example I know my preamble is 16 identical bits, however I am not seeing 16 identical pulse times; only lets say 3 identical bits in a row are detected.
My nominal data rate is 3.7 kB/s ~3.2 -> ~4.2. The data Word I am decoding is 64 bits that have a max duration of 312.5uSec. I am not sure clock wise what my freq should be .. or what I should be offloading to additional COGS.
I will post somecode when I get home from work and see if I am even on the right track.
John
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler Largos - upcoming nano operating system
I might have not been so clear as to the speed, since I wrote that post from my Blackberry in DC traffic. The duration of each bit has a max of 312uS, making the complete packet (64 bits) ~24mS
Not that it helps me much to understand my signals performance specification because I don't yet fully understand the Speed limitation of Spin code, nor the relationships between clocks rate (freq), counter speed, and code execution speed. Meaning that when the Prop is running at X speed, Y lines of code execute over T amount of time. Also is there a relationship between the counters speed (when used as a Pos/Neg detector) and clock speed (Spin Vs PASM)?
I guess I was hoping for some code objects that were built for manchester... but I will continue to hunt and pec. I also am having some Forum anxiety posting the code I butchered from Sir JohnnyMac [noparse]:)[/noparse] . His pulse measuring code does use PASM, however its getting the raw measurement times from the COG running the PASM, decoded into the binary string.
-John
If you need to use PASM mixing Spin and PASM works much differently than on other platforms, since you can't call PASM code inline; you have to write a standalone PASM routine that waits for orders dropped in a chosen location in Hub RAM (sometimes called a mailbox, generally passed via the 'par' parameter when the cognew is issued) and the Spin code has to leave such requests and wait for the PASM code to answer by leaving the answer somewhere else and maybe clearing the request. It sounds awkward but it's also extremely powerful, since you can have multiple Spin cogs using a common PASM resource this way.
edited to correct bonehead miscalculation of PASM instruction time
Post Edited (localroger) : 3/4/2010 2:05:47 AM GMT
Back to my original problem ....
To decode the manchester signal, it sounds like I will need a COG that runs an PASM method that reads the input from a counter (or 2) and then places that raw input into a place in memory (a... hub address?..) that can be read in "near real time" by another COG..... does that sounds right ?
--Manchester Decoding--
COG 1 (SPIN)
-Launch another COG that does the hard stuff
-Gets the stuff from shared memory that COG 2 stored
-Run a loop to parse the data stream into segments
---Identify preamble
---Identify data segment
---Do some CRC stuff
-Send data to somewhere else to have something else done with it
COG 2 (PASM)
-Start up some counters
-Get the data from the pins
-Make the counter triggers into something useful
-Put the something useful into memory
You will pass your stuff in Hub RAM. From Spin, you'll define one or more VARs. It's best if you need more than one to use an array of longs, as Spin creatively rearranges the order of variables in some cases. So you have a VAR segment and define PASM_PARMS[noparse][[/noparse]10] because you need 10 values, indexed from 0 to 9. Then you COGNEW(pasm_code, @pasm_parms). The @ tells Spin to return a pointer to where the array is at.
On the PASM side you'll use the par register to locate pasm_parms; you can see examples of how to do this in just about every obex object that uses PASM. You'll probably want to RES pointers to your individual pasm_parms values and calculate them when the PASM code starts, so instead of having to access pasm_parms by adding 3<<2 to par, you can just refer to something meaningful like start_val. You will actually read and write to pasm_parms with the rdlong and wrlong commands. These move data between hub and cog RAM. They're special instructions that take longer to execute than regular cog instructions because they have to wait for the hub to sync to that cog, so you don't want to use Hub RAM more than necessary, but it's how you transfer data between Spin and PASM processes.
There are many good examples of how to do this in the obex; check out the fullduplexserial or tv_text objects for example.
Unfortunately; your correction was too late and mis-calculations caused my rocket full of kittens to be lost forever. I'm kidding of course, and thanks for the attention to detail from yourself as well as the secret forum auditors [noparse]:)[/noparse] .
I will spend a few hours with this tonight to see what I can slap together.
Thanks again
-John
John
Then I'd say the way to go is:
1. use waitpeq or waitpne to wait for the start-bit
2. use the waitcnt to wait for the 3/4 clock cycle
3. read a bit
4. go back to 2 until all 64 bits have been read
Of course there would be another way of decoding a manchester.
Run a counter that counts high-time, run a counter that counts low-time of the signal
On each high-low or low-high edge you verify the high/low-counter alternatingly. If it's a long signal you have to record the bit and flip the bit for the next record, if it's a short signal you'd simply record.
You said "I'm not sure wheather you need counters .. do you want to use the 3/4 decoding now?"
It is not so simple tha only "want to use 3/4 decoding now" as Manchester code as I understand it correctly are variable speed code.
That means as Clock periods betwen sepatarte pulses can vary - To have good Manchester code demodulator YOU need Syncronise reading on every Clock pulse.
Regards
Christoffer J
Ps. With other words It is self contained code that need demodulate every Clock pulse and Data bit in its period.
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
Post Edited (Sapieha) : 3/4/2010 11:38:42 AM GMT
So, it's not really variable frequency! But the result of encoding will have exactly 2 different high/low-times.
If you send only 0s or only 1s, the resulting signal will have the same frequency as the clock.
If you send 010101010101......., the resulting signal will have half of the clock frequency.
PS:
For decoding you can now use the fixed clock frequency to sample the signal (that's the 3/4 bit time method described in the document as linked in the second post)
you can decode by measuring the high and low times. Whenever the high or low time is 2 times the clocks high/low-time the bit has been flipped ... whenever the high or low-time is equal to the high/low-time of the clock then the same bit as before has been transferred again.
Post Edited (MagIO2) : 3/4/2010 1:12:49 PM GMT
I brainstormed together a notional list of decoding methods to keep track of them all in once place and when this is all said and done, we will have a single graphic (flow chart) that lists the methods/pros/cons/code etc.
Sapieha, You are correct that the CLOCKING IS essential to being able to extract (decode) the stream. Depending on the bit rate in relation to the decoders time slippage or time slippage from the transmitting clock circuit, the decoder may have to adjust its clock sample routine to stay in sync. My thought was that with a 16 bit preamble at a bit rate of only ~ 3.2 kbS, that if I used a mid-bit method I would not drift clock enough to make a difference... at least within my 64 bit packet.
MagIO2,
Appreciate the feedback. I would be lying if I said I had not scoured over ever post in all forums on here with the words Manchester,bi-phase, and bit bang; to see your name in just about every thread. Since I am a newbie to the Spin/Prop, I look forward to forgetting I read all of your old posts and only asking questions you have answered somewhere else before.
This forum is like a 12 step program. I know I could get my FIX from some dirty controller or language that I already know. However, every time I come back to this site and see what people are doing, and the level of inovation I remind myself that I must stay clean, and that I am powerless over the feeling of making things work the easy way (Without PASM).
3/4 bit cycle method can be implemented allowing flexible clock timing as well. Your first bit will be a start bit. So you can use that start bit for measuring the clock-frequency and then wait for the 3/4 bit cycle of the first data bit. But that's only needed if you connect to a device that has a drifting clock-frequency. If you can be pretty sure that your device uses a fixed frequency which is not drifting to much, a sync to the start bit is enough.
Table based?
You want to record the whole signal and compare it to a list of 2 to the power of 64 entries??
Post Edited (MagIO2) : 3/4/2010 2:30:18 PM GMT
Correct, I was mixing too many thoughts at once. What I meant to describe was using the Mid-bits to extract the clock. I was not sure if I would have to use the extracted clock, perhaps even in another COG to invoke the sampling of the data in another COG.
Center Sampling is sampling at the time furthest from the signal transition. Therefore center sampling in Manchester occurs at points 1/4 and 3/4 through the cell, since transitions occur always at mid-bit and sometimes on the cell boundary.
Regarding the tables:
I had seen several examples of people creating two tables with 256 entries. One table is a direct mapping of an 8-bit byte into a 16-bit Manchester encoding of the byte. The second table is a mapping of a Manchester encoded 8-bit byte to 4 decoded bits.
Some other more protocol/implementation specific tables link a specific manchester encoded bit pattern directly to a predefined value. This in my case would actually work ok since I am only receiving packets from a sensor that has a very predefined set of values. I would much rather build an object that I can adjust and reuse though .
I had looked through that PDF, as well as like 10 others. My problem is more learning how to do it in Spin.
I will have it completed by tonight and will post my code for critique.
-John
I would like to do something similar decoding a 134.2 kHz biphase RFID tag (FDXB).··Unfortunately, my skills are not sufficient to accomplish this task.
Lawson
Lunch cures all problems! have you had lunch?
I appreciate the info. I am working with a 3.52KHz signal, so from what you have tested I should be able to make it work with Spin. If I can't I will just pull out the PASM guide and start playing with that.
- John
This provides a nice demo of ViewPort's power. Here's what I came up with in half an hour:
{*************************************************** * (C) 2010 HannoWare.com, Inc. * * Machester Encoding Tutorial * * AppletImage=scope.gif * **************************************************** Generate and decode Manchester encoded signals. Run this with ViewPort v4.2+ Use the dOut box to send a specified value in Manchester encoding. You'll see the sequence and the decoded value.} CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 'use standard 5MHz clock ManPin=16 dbgPin=17 OBJ 'include 2 ViewPort objects: vp : "Conduit" 'transfers data to/from PC qs : "QuickSample" 'samples INA continuously in 1 cog- up to 20Msps VAR long period 'period of clock long dataOut '32 bits of data to write long dataIn '32 bits of read data long frame[noparse][[/noparse]400] 'stores measurements of INA port long stack[noparse][[/noparse]100] 'stack for decode cog pub generateManchester|d,tcnt vp.register(qs.sampleINA(@frame,1)) 'sample INA into <frame> array optional_configure_viewport 'optionally configure viewport's interface vp.share(@dataOut,@dataIn) 'share the data variables dira[noparse][[/noparse]ManPin]~~ 'output pulses on pin 16 cognew(decodeManchester,@stack) 'start a cog decode the code period:=clkfreq/(3520*2) 'period is twice clkfreq/frequency tcnt:=cnt+period repeat d:=dataOut outa[noparse][[/noparse]ManPin]~~ repeat 32 'start with 1 if d & 1 'output lsb first waitcnt(tcnt+=period) 'on a 1, output rising outa[noparse][[/noparse]ManPin]~ waitcnt(tcnt+=period) outa[noparse][[/noparse]ManPin]~~ else 'on a 0, output falling waitcnt(tcnt+=period) outa[noparse][[/noparse]ManPin]~~ waitcnt(tcnt+=period) outa[noparse][[/noparse]ManPin]~ d>>=1 'rotate right to get next highest bit outa[noparse][[/noparse]ManPin]~ 'leave at 0 waitcnt(tcnt+=period*100) pub decodeManchester|d,tcnt dira[noparse][[/noparse]dbgPin]~~ repeat waitpeq(|<ManPin,|<ManPin,0) 'wait for begin of code tcnt:=cnt-period*1/2 'delay into middle of bit d~ repeat 32 waitcnt(tcnt+=period*2) if not ina[noparse][[/noparse]ManPin] 'input lsb first d+=1 d->=1 'rotate right to get next highest bit dataIn:=d !outa[noparse][[/noparse]dbgPin] waitcnt(tcnt+=period*10) pub optional_configure_viewport vp.config(string("var:io(bits=[noparse][[/noparse]16sig,17dbg]),dOut(base=16),dIn(base=16)")) 'view IO pins, and dOut,dIn in hex vp.config(string("lsa:view=io,timescale=1ms,trigger=io[noparse][[/noparse]16]r")) 'view with lsa- timescale set to 1ms, triggered on pin 16 rise vp.config(string("edit:dOut(mode=text,default=85)")) 'edit the dOut variable with a textbox vp.config(string("start:lsa")) 'start in lsa viewIt lets a user specify a 32bit value to transmit on pin 16 in Manchester encoding. It uses another cog to decode data on that cog- hopefully it arrives at the same number! (it does)
It's all in simple spin- plenty fast for both the generation and decoding. Attached is a screenshot- notice that with a $55 pattern, the beginning sequence is as slow as possible. Later, the sequence transitions twice as fast- once for every 0. This will be in future versions of ViewPort- or paste from above and try it out!
Hanno
Co-author of the official Propeller Guide- available at Amazon
Developer of ViewPort, the premier visual debugger for the Propeller (read the review here, thread here),
12Blocks, the block-based programming environment (thread here)
and PropScope, the multi-function USB oscilloscope/function generator/logic analyzer
ViewPort looks great ... guess sooner or later I have to purchase a copy.
But somehow the attached picture looks strange. Shouldn't the pulse and pause-times for the $0000_00-part of the long be identical? It's obviously because of scaling the signal down/up to the size of the window. Is ther a mode where you only scale by non-fractional scaling factor?
PS:
Can you try the same with $AA? I think it would be better to send a start-bit first!
Code of reading then could be made timing independent·by measuring the length of the first pause.
Post Edited (MagIO2) : 3/8/2010 8:31:47 AM GMT
I used the 1ms timescale to show all 32 encoded bits on one screen. Of course you can select a faster timescale to more accurately analyze the individual pulse lengths.
I'll take more screen-shots and post a tutorial of steps I took to get to the result. I'll show different patterns- but notice that I start and stop the sequence with 1 and 0.
Hanno
Much appreciated !
I have been using Viewport and the Parallax USB scope. I CAN'T wait to get my USB Prop Scope in the mail tomorrow. I know you put a ton of work into the new scopes HW/SW design.
What equivalence does the software that comes with the Prop Scope have to Viewpoint?
-John
