I2C eagle Tree Airspeed sensor
Good morning all,
I am trying to read an eagle tree airspeed sensor and have absolutely NO idea of what I'm doing.
The data sheet is not fantastic;
http://www.eagletreesystems.com/support/manuals/microsensor-i2c.pdf
Here is the code I have written;
' {$STAMP BS2px}
' {$PBASIC 2.5}
SDA PIN 13 ' I2C SDA pin
SCL PIN 12
addr VAR Word ' internal address
result VAR Byte(2) ' array for returned value
speed VAR Word
START:
DEBUG CR, "Reading...", CR
PAUSE 1000
addr = $EA
I2CIN SDA, addr, [noparse][[/noparse]STR result\2]
speed = result(0)*256 + result(1)
DEBUG "out 0 = ", speed
GOTO START
END
I'm very confused as to the difference between slave ID and address.
Any help would be great.
Thank's,
Istha
The robot is going to lose. Not by much. But when the final score is tallied, flesh and blood will beat the damn monster.
Adam Smith
' {$STAMP BS2px}
' {$PBASIC 2.5}
SCL PIN 12
speed VAR Word
START:
PAUSE 1000
addr = $EA
GOTO START
END
Thank's,
Istha
Adam Smith
Apparently only pins 0&1 and 8&9 work for I2C.
I
Adam Smith
