Best way to detect light color or frequency for Prop based Spectrum Analyzer
I am wondering which sensor or technique would be best for determining light color or frequency with a Prop chip with the intent of making a cheap Spectrum Analyzer?
Both the ColorPAL and the TAOS sensors seem like they are orientated to the color of objects, not ambient light. Is this correct?
What about a Phototransistor or the Photoresistor? They seem like they only handle "white" light? The Blue-Enhanced Photodiode looks from the datasheet that it might be able to discern individual light components?
My plan was to use a Full Color LED that has RG and B lines, vary those with Digital Potentiometers to get some different base readings and then use 2 of the Light Intensity to Square Wave Frequency chips and compare the outputs?
Now I have every intent of doing some experiments to test some things and try them out, but I really don't want to buy a ColorPAL or the TAOS sensor only to find out they wont really do what I want. I already have some Photoresistors, the Diode and Light Intensity sensors...
Thanks for any help
Often the joy is not so much in the having, its in the building...
Thanks for any help
What is your final objective with this? There is much you can measure with an RGB detector like the TCS3200.
Thanks, will get the TAOS if its my best shot. I guess.
Crazy ideas, huh? Thanks Phil
