Crystal Frequency ????
I was just reading about a new Prop dev board someone had made and was considering offering for sale. One of the first things I noticed in the first pic I looked at was a 10 MHz crystal ... my mental comment was "I wonder why he picked that?" After some thought the only answer I could come up with was "I haven't the foggiest!"
Now the more I thought about it the more I realized that I really had no idea what the considerations were.
So, in my quest for enlightenment, I pose this question for the assembled multitudes ... "If I am going to design a Prop board. Why might I chose crystal/pll pair of 10 MHz/8x over 5Mhz/16x? What are my considerations? What are my tradeoffs?"
cheers ... BBR
cheers ... brian riley, n1bq, underhill center, vermont
The Shoppe at Wulfden
www.wulfden.org/TheShoppe/
cheers ... BBR
propeller.wikispaces.com/Oscillator
OBC
New to the Propeller?
Leon Heller
Amateur radio callsign: G1HSM
Thanks for the info guys ... I am looking forward too seeing if anyone else has something to add.
cheers ... BBR
so the higher the crystal speed the higher the speed of the prop chip itself I hope that helps.
Smaller physical size is the only reason for choosing 10 Mhz over 5 MHz, and then only if you're designing a surface-mount board. You will not be able to use a 10 MHz crystal with PLL16x to get 160 MHz.
I use 10Mhz XTALs just because I have a bucket load of them.
From overclock testing it seems higher xtals and *8 works better. Sapieha has 15MHz xtal on the TriBlade running 120MHz for nearly a year now.
My RamBlade works with a 14.31818MHz and *8, but 7.3...MHz *16 does not (14.6MHz). 15MHz *8 did not work. This has not been extensively tested though. Note 14.31818MHz is an NTSC frequency and is readily available.
Maybe there's something I'm missing.
@Cluso, BTW, I was able to get my demoboard to run just fine at 14.31818MHz * 8, but not the 13.5*8. They both seemed to communicate just fine, but the 13.5MHz crystal just wouldn't do VGA. 14.31818Mhz on the same demoboard worked great.
Doug
