LCD tachometer help
Im currently using this code to display RPM and a bargraph on a LCD screen.
The problem is that i have 4 zeros infront of RPM and i dont want them to be there.
I know that its because of the DEC4 command in the subroutine Def_Horiz_Bar_Char:.
Does anyone know of a way to get around this problem.
' -----[noparse][[/noparse] Title ]--------------------------------------------------------------
' Smart Sensors and Applications - HorizBarGraph.bs2
' Display values entered into the Debug Terminal's Receive windowpane
' as horizontal bar graph data in the LCD.
' {$STAMP BS2}
' {$PBASIC 2.5}
' -----[noparse][[/noparse] I/O Pins ]-----------------------------------------------------------
LcdPin PIN 15
SpeedIn PIN 0
' -----[noparse][[/noparse] Constants ]----------------------------------------------------------
T9600 CON 84 ' True, 8-bits, no parity, 9600
Capture CON 5000
LcdCls CON 12 ' Form feed -> clear screen
LcdCr CON 13 ' Carriage return
LcdOff CON 21 ' Turns display off
LcdOn CON 22 ' Turns display on
Line0 CON 128 ' Line 0, character 0
Line1 CON 148 ' Line 1, character 0
Define CON 248 ' Address defines cust char 0
' -----[noparse][[/noparse] Variables ]----------------------------------------------------------
rpm VAR Word
pulses VAR Word
percent VAR Byte
custChar VAR Nib ' Custom charcter selector
index VAR Nib ' Eeprom index variable
dotLine VAR Byte ' 5-pixel dotted line
cursor VAR Nib ' Cursor placement
value VAR Byte ' Value to be graphed.
charCnt VAR Byte ' Character counting variable
line VAR Byte ' Line0 or Line1
' -----[noparse][[/noparse] Initialization ]-----------------------------------------------------
PAUSE 100 ' Debounce power supply
SEROUT LcdPin, T9600, [noparse][[/noparse]LcdOn, LcdCls] ' Initialize LCD
SEROUT LcdPin, T9600, [noparse][[/noparse]137, "RPM" ]
PAUSE 5 ' 5 ms delay for clearing display
custChar = 3 ' Select Custom Character 3
dotLine = %11111 ' Black all pixels in each line
GOSUB Def_Horiz_Bar_Char ' Character define subroutine
line = Line1
DO
GOSUB Acquire_RPM
value = (RPM / 35)
GOSUB Bar_Graph:
LOOP
' Acquire_RPM
Acquire_RPM:
COUNT SpeedIn, Capture, Pulses
rpm = (pulses * 12)
RETURN
' Bar_Graph
Bar_Graph:
' Fill from left with black bars
value = value MAX 100
charCnt = value / 5 ' Number of black bars
custChar = 3 ' Choose black custom character
IF charCnt > 0 THEN ' If black bars to print then
FOR cursor = 0 TO charCnt - 1 ' Print charCnt - 1 black bars
GOSUB Disp_Cust_Char ' Print the black bar
NEXT
ENDIF
' Display Custom Character 2 with a certain number of black columns.
cursor = charCnt ' Place cursor
custChar = value // 5 ' How many 5ths of a bar?
' Choose bit pattern for custom character definition
LOOKUP custChar,
[noparse][[/noparse]%00000, %10000, %11000, %11100, %11110],
dotLine
custChar = 2 ' Set custom character to 2
GOSUB Def_Horiz_Bar_Char ' Define the custom character
GOSUB Disp_Cust_Char ' Display the custom character
' Print over everything to the right with spaces.
IF (charCnt + 1) < 15 THEN ' Partial char left of char 15?
FOR cursor = (charCnt + 1) TO 15 ' Fill to right with " "
[noparse][[/noparse]line + cursor, " "]
NEXT
ELSEIF value = 80 THEN ' Special case: value = 80
[noparse][[/noparse]line + cursor, 3]
ELSEIF charCnt = 14 THEN ' Special case: 75 <= value <= 80
SEROUT LcdPin, T9600, [noparse][[/noparse]line + 15, " "]
ENDIF
RETURN
' Def_Horiz_Bar_Char
Def_Horiz_Bar_Char:
SEROUT LcdPin, T9600, ' Define custom character
[noparse][[/noparse]Define + custChar]
FOR index = 0 TO 7 ' 7 bytes, define 7 dotted lines
SEROUT LcdPin, T9600, [noparse][[/noparse]dotLine] ' Send it to the LCD
NEXT
SEROUT LcdPin, T9600, [noparse][[/noparse]133, DEC4 rpm]
RETURN
' Disp_Cust_Char
Disp_Cust_Char:
SEROUT LcdPin, T9600, ' Print custom character
[noparse][[/noparse]line + cursor, custChar]
RETURN
But maybe before this...
SEROUT·LcdPin,·T9600,·[noparse][[/noparse]133,·DEC4·rpm]
Maybe something like...
SEROUT·LcdPin,·T9600,·[noparse][[/noparse]133,·"··· "]
And instead of the above...
SEROUT·LcdPin,·T9600,·[noparse][[/noparse]133,·DEC·rpm]
If that does not work, might want to say which specific LCD you have and give a link to the instruction manual.
Or to explain this, here is a count down example which leaves the 1 there...
(Should count down from 12 to 7)
12
11
10
19
18
17
And a correction for that...
(Send spaces and it gets rid of the 1)
12
11
10
·9
·8
·7
So we have this and I was wondering what the 133 was for...
Looking in the directions for the LCD, it means...
133· Move cursor to line 0, position 5
So that gives us more options! Because there are more of these commands in the instruction manual...
128 Move cursor to line 0, position 0
129 Move cursor to line 0, position 1
130 Move cursor to line 0, position 2
131 Move cursor to line 0, position 3
132 Move cursor to line 0, position 4
133 Move cursor to line 0, position 5
134 Move cursor to line 0, position 6
135 Move cursor to line 0, position 7
136 Move cursor to line 0, position 8
137 Move cursor to line 0, position 9
So you could do this...
SEROUT LcdPin, T9600, [noparse][[/noparse]128, " "]
SEROUT LcdPin, T9600, [noparse][[/noparse]129, " "]
SEROUT LcdPin, T9600, [noparse][[/noparse]130, " "]
SEROUT LcdPin, T9600, [noparse][[/noparse]131, " "]
SEROUT LcdPin, T9600, [noparse][[/noparse]132, " "]
SEROUT LcdPin, T9600, [noparse][[/noparse]133, " "]
SEROUT LcdPin, T9600, [noparse][[/noparse]134, " "]
SEROUT LcdPin, T9600, [noparse][[/noparse]135, " "]
Or...
SEROUT LcdPin, T9600, [noparse][[/noparse]131, "··· "]
Depends on where position 0 is!
Experiment and see what happens...
FYI - Here are the LCD instructions. Note on page 11 it shows various characters. And one of the characters listed is blank! (Nothing). You could send that character to overwrite a zero...
http://www.parallax.com/Portals/0/Downloads/docs/prod/audiovis/SerialLCD-v2.0.pdf
Post Edited (bill190) : 3/1/2010 3:42:39 PM GMT
