ERROR : No Basic Stamp found !!!!!
Hi,
I'm facing a new kind of problem here with Basic Stamp :
When I try to run a program the computer can not read the Basic Stamp anymore and an error message similar to the one that appears when the board of education is off shows up in my screen "No Basic Stamp found", sometimes I have to restart the whole system so that it can read the connection with the Basic Stamp again. Even though, sometimes the program can't execute the code and the Robot stays fixed, I tried it with my old classical codes that used to work properly and still have the same problem. This is driving me really crazy and I need to understand what's really going on here !!!
Vin to Vss =
Vdd to vss =
Rst to Vss =
Vin should read the same as your power source.
Vdd should read 5 volts.
Rst should read 5 volts.
Dave
Dave Andreae
Parallax Tech Support·
Vdd to VSs : 4.4 V
I don't see what you mean by Rst.
I want to add that sometime the system can ensure the connection with BS2 but the robot doesn't want to move anymore, or it moves for a while then it stops ( I'm sure about the code, it used to work before).
Thanks for replying.
C-Bob
Every problem·have at least one·nice, simply and·wrong solution.
Vdd to Vss : 4V
Vin to Vss : 4 V
This is drinving me crazy, the hexcrawler does not move and I can't do any presentation anymore.
Change power supply.
C-Bob
This is not a low dropout voltage regulator. I believe it is a standard 7805.
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
