calibration circuit suggestions
I am in need of a circuit that can output a calibration value of 0.1 mv, and 40mv. I suppose I could buy a fluke 715 www.myflukestore.com/calibrators/loop-705_707_707ex_715.php but I don't feel like have two or three of these $700 items floating around. Right now I have been using a voltage divider (pot) with a 1.5v alkaline cell, and I use a separate multimeter to view the output. I want to make a few calibrators which only have two or three preset outputs.
Does anyone know of a inexpensive item that would work, or a simple circuit that could be easily produced? I have considered using a precision voltage reference, divided with precision resistors, but I am not sure that would be accurate enough, as accuracy needs to be within 0.05 mv, and the resolution on the instrument to be calibrated has a .025mv resolution.
www.national.com/ds/LM/LM4050.pdf
Leon Heller
Amateur radio callsign: G1HSM
www.analog.com/en/amplifiers-and-comparators/current-sense-amplifiers/ad628/products/product.html
Produce whatever output you want.
@Todd Chapman, with a min gain of .1, and an offset of +-1.5mv, that would equate of .15mv that would need to be calibrated somehow, unless I am not understanding your usage idea.
Leon Heller
Setting up a 0.1% or greater current source doesn't seem any easier to me.
There is no getting around the fact that you either need a calibrator for your calibrator, or you need to start with components of high precision. Maybe you can find a lab at a school or local industry that would give you half an hour to adjust your trimmers alongside a trusted 6 digit or better multimeter.
I bought an Extech CMM-15 process calibrator/multimeter several years ago, and while not as pricey as the Fluke 715, it has been an indispensable tool because of the frequent of calibration and linearity testing I need to do in various ranges. These things are not without shortcomings. In the range of 40mV or 0.15 mV, I would find much too much noise on the output. (Noise is due to the switching power supply that generates the +/- 15 volts inside the meter) I need to do millivolt level testing quite often, so I built external circuits using precision voltage dividers, filtering, and CAZ op amps (LTC10551), to bring down 0 to 10 volt from the Extech to 0 to 100 mV or 0 to 10 mV or 0 to 100 microAmp for device under test.
Tracy Allen
www.emesystems.com
One of these search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=811-1054-ND
Plus one of these search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=GU2021S26-ND
I am going to set up a voltage divider based on a 1.5v battery, and I'll tie the output to the meter, and to the outgoing leads. The murata engineer seemed to think his panelmeter was up to the task, so I am going to give it a try.
