modify serin command
Hi all.
My Name is Daniel from Switzerland and I am new in that forum.
In order to read serial TTL data from external device, I need to set the serout format to B9600,E,9,1.
Is it possible to do this with my BS2px?
Thanks for any answer.
Daniel
Daniel
The BS2px can handle 9600 baud just fine, but 9 data bits will be a major source of irritation. The usual settings are for 96008N1 or 96007E1.
What kind of device are you interfacing with? Sounds like a modem. Is there a chance of changing its byte size to 8 or 7 bits?
Cheers,
Tom Sisk
http://www.siskconsult.com
Thanks for Your reply.
Unfortunately there is no chance to change or adust on the sending device. It is a rc duplex system from Jeti http://www.jetimodel.cz/index.php?page=product&id=34.
I found out in some forums, that is one of a possible way (without using of a microcontroller) to get correct data from that device.
Best regards.
Daniel
