Videoing LEDs
I have a Canon A560 and I'm trying to "video" some RGB LEDs.· The Cyan, Blue, and Magenta·(aqua, blue, purple - whatever), and pretty much the White, too,·come out looking like blue, like there's no transitioning.
The Canon has some lighting and saturation settings (presets), but I haven't found a winning combination.·
And in getting close up, they wash out like.
How do I get better results?·
If that's not possible with this unit, then what should I look for in a camera which definitely can?
For leds you can try to get the multiplexing frequency high enough that every led is lit several times per frame. This is particularly difficult for RGB leds since each color needs to be lit several times per frame. Getting the color right is also a problem since the sensitivity of the eye is different from the camera imaging chip for the wavelengths of RGB leds. The camera chip is optimized for incandescent lamps or daylight. Filters might help.
As far as Cams to buy
I use a 1Dmk2 as my main dSLR
and a S5-IS as my backup cam and my only Video recrding cam .
( used to own a XL1 )
the S5 shoots wonderful video max resuation in Video mode is VGA ,
the S15-IS ( latest model out ) shoots 720 HD .
EDIT I have shot RGB LED light bars with it with nno huge issues ..
Peter KG6LSE
"Carpe Ducktum" "seize the tape!!"
peterthethinker.com/tesla/Venom/Venom.html
Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
LOL
Try putting the camera on a sun setting but then you wouldn't be able to take video [noparse]:p[/noparse]
