RCTIME and COUNT through an Analog Switch — Parallax Forums
G McMurryG McMurry Posts: 134
edited 2010-02-19 18:51 in BASIC Stamp
Has anyone been successful expanding the IO pins of a Basic Stamp through an analog switch? I have several voltages I want to monitor using RCTIME and was considering the MAX4617 to expand my Basic Stamp..
THANKS
Greg
AUTOMATE EVERYTHING
http://www.trainyard.net
    edited 2010-02-19 17:49
    Using a MAX4617 should work. You need to respect the voltage limits of the MAX4617.
    You may do better with a multi-channel SPI ADC like the MCP3208 because it only needs 3 I/O pins to work with the Stamp (Din and Dout are connected together).
  • G McMurryG McMurry Posts: 134
    edited 2010-02-19 18:20
    I have already designed a board using an ADC but the conditioning I need for each input started making me look at OpAmps and additional voltages on each channel and that got pretty hungry with board space.
    The precision I get with RCTIME is fine for my application...
    I see what you are talking about with the voltage limit of the MAX4617. I will see if I can find another device.
    Another idea might be just to use the 2p 40 pin version. Then I might have enough IO with out expanding...
    Thanks!
    Greg
    AUTOMATE EVERYTHING
    The original CMOS family has much wider voltage range. Applicable devices would be the
    CD4066, quad analog switch
    CD4051, single 8 to 1 analog mux
    CD4052, dual 4 to 1 analog mux
    CD405, triple 2 to 1 analog mux
    Tracy Allen
    www.emesystems.com
