What is the proper format for .spin files?
Clock Loop
I get this error in PropellerTool when modifying the spin file outside of PropellerTool.
-Unicode?
-Ansi?
-Unicode?
-Ansi?
As soon as you add such a symbol it will want to store the file as Unicode text rather than ASCII so as to preserve all your nice diagrams and such.
Personally I'd rather forgo the fancy fonts and have all my source files as ASCII.
Specifically UTF-16. The Propeller tool saves the file as unicode as soon as you add any non-ASCII character to the file.
As far as I can tell, the warning dialog is simply letting you know that it is about to double the size of your file and re-encode it in a format other than the one it was when you loaded it.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should use WD40.
Not me, I LIKE the ability to use fancy fonts, and schematic symbols.
Its not easy to include good schematics with projects in code.
Many have tried only to end up with a file that looks wrong on end users pc's, totally useless to them.
So looks like the answer is Unicode, thank you.
