Can you overclock the propeller with extreme measures?
Can you overclock the propeller chip by using ethylene glycol or some kind of non conductive coolant or by using water cooling and a radiator?
http://en.wikipedia.org/wiki/Overclocking
http://www.pugetsystems.com/submerged.php
Post Edited (Chuckz) : 2/17/2010 2:07:52 PM GMT
Its been proven to work as good as 80Mhz operation.
Nyamekye,
This has been asked over and over again. Unfortunately, without decent search capabilities, the same questions get answered over and over again because people cannot find the answers.
Here are some threads about overclocking:
http://forums.parallax.com/forums/default.aspx?f=25&m=215415
http://forums.parallax.com/forums/default.aspx?f=25&m=297000
http://propeller.wikispaces.com/Oscillator
http://forums.parallax.com/forums/default.aspx?f=25&m=228279
The real question is what are you trying to accomplish? Is it higher signal frequencies? If so, overclocking might be the best way to do that. If it is more computing power for your application, might I suggest adding another propeller. Yes, there is overhead, but you could get 14 cogs instead of 8 with 2 of them tied up doing communication..
Doug
I think a forum for beginners might take some weight off of the general forum and promote the prop by enabling more people to use it.
Thank you (all) for answering my question.
The experts like Heter, BradC, PhiPi, rokiki, Mike Green, Kye, etc. lurk here with their own projects, and they are some of the best to answer questions of newbies and experienced prop programmers alike.
If there was a beginner's forum, they would have to check there as well as with the discussions on their own projects. Plus, I like a level playing field, a classless. I admit, I am a novice, when it comes to prop programming, I don't want my posts bounced to another forum because it doesn't qualify as anything but "beginner".
just putting in my 10 bits
Doug
P.S. @chuck I just noticed that you where the original poster. My rant above was not against you as some sort of "dumb" or "beginner" question, but rather at the lack of search capability. Your question is perfectly valid, and I enjoyed the links you sent as well.
Post Edited (hinv) : 2/17/2010 6:05:27 PM GMT
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
pPropellerSim - A propeller simulator for ASM development sourceforge.net/projects/ppropellersim
site:forums.parallax.com inurl:"f=25" servo
Stick that in google, an example of a search for servo.
The problem is that it does not always show the title of the thread, I don't know why this is.
Graham
