I2C and Prop at 33 feet
I have been testing out some longer I2C runs, using the PCF8574 8 i/o expander with the Prop. One test uses a 33' CAT5E cable, where clk and data are on one twisted pair, and power and ground are on another pair. I didn't have any reason for choosing this wiring scheme. Another test uses two legs of cables, both 20' each off the Prop data/clk to two of the 8574 devices. These are used on the same controllers that contain motor drivers using mosfets. Soon I will buy a 250 roll of CAT5E and see what happens. The driver is the minimal I2Cdriver object.
I thought I recall reading that these type lengths were not doable with I2C, maybe I am mistaken, but in my cases everything is behaving nicely.
Anyways, just an observation.
You have me beat for simplicity of your explanation. Better than my college-level mish-mash-just-to-show-you-how-smart-I-am explanation
JMH
