Finding the max number
How would one go about finding the max number out of two or more values? For example, in java the command·" z = Math.max(x, y); " z is assigned the highest value between the two numbers compared, x and y. I searched the propeller manuel and did not find any similar command. If such a command did not exist, could someone suggest a piece of code that could do the same function.
"You do not really understand something unless you can explain it to your grandmother."
-Lucky[size=-1][/size]
Yeah...
And, if you have more than one value...
' n is the size of the array of numbers z := numbers[noparse][[/noparse]0] repeat i from 0 to (n - 1) if(numbers[noparse][[/noparse]i] > z) z := numbers[noparse][[/noparse]i]▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Nyamekye,
Post Edited (Kye) : 2/14/2010 8:59:30 PM GMT
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
pPropellerSim - A propeller simulator for ASM development sourceforge.net/projects/ppropellersim
Jon McPhalen
Hollywood, CA
