WARNING!! StingRay/MRS1 3.3V No regulation? Help Me Test Please Reply
After hours of looking at my code, I decided to check voltages, at Vin above approx 9.0V the program quit, and have found I believe a serious problem.
I have a MRS1 board on my test bench fed by a high quality variable power supply. I am measuring the voltages at the 3.3, 5.0 and Vin female headers at the front of the board (as well as the jumper holes·at the translators).· I have nothing connected to the I/O headers or H-bridge.
Vin follows very close to the power supply 7.2-12V, V5.0 is well regulated and stays at about 4.95V with pwr supply varied 7.2-12V, however,·at the 3.3 female header (and other points) I am getting 3.87 - 6.06V as I varied the power supply 7-12V!!!!! No regulation...
Does anyone have the ability to test their board at the 3.3V header·with an adjustable power supply·from 7.2 - 12V, so I may compare. I tried Power to both the co-axial and molex Vin points as well with no difference (the schematic shows them as the same).
Please, Help me Obi Wan...You're my only hope..
It sounds like you do have some sort of problem. However, Obi Wan is not your only hope. Parallax Tech support is excellent and will help get you free from the dark side. Give them a call and may the force be with you!
Whit+
Sounds like you do in fact have a problem.
Jim-
Signature space for rent!
Send $1 to CannibalRobotics.com.
Duffer
Any technology, sufficiently developed, is indistinguishable from magic.· A.C. Clark(RIP)
or between the 2 pins of that 5V and 3.3V headers? Before that, everything worked fine? I had a failing MSR1 as well, and it was replaced.
I am so lucky to be just a little less than an hour away from Parallax, so I drove down and met with Dave at tech support. PARALLAX SERVICE AND SUPPORT IS SECOND TO NONE!!! IMHO and experiance. We tested again and now the 3.3 was good but the 5.0 varied on 12v battery supply, and then the 3.3 varied on a bench supply. In the end I got a new MRS1 board.
Thanks for your help Dave, good talking with you Joshua.
I then went to the sales and bought a gyro, cables and temp sensors that I want to put on my HB25s to switch the fans only when necessary and another MRS1 board. The whole crew at Parallax are so helpful. They even gave me a couple of band-aids (Propeller Hat stickers) just to make me feel better. What a difference to work with people that care about the customer.
Anyway, thanks again for checking and helping me form a conclusion. My bot might be mobile tonight.
rpdb
BTW the reason I said "warning" is to alert others so they might test and·would not ruin anything with 6.0 volts applied to a 3.3 volt device. GND is the mounting holes or black I/O pins.
Post Edited (rpdb) : 2/13/2010 2:07:10 AM GMT
Glad you've got your problem resolved. Wish I could just drive over to Parallax!
Whit+
Maybe I should check my boards. The one on my plywood stingray seems to be working correctly.
Tony
- Stephen
Good idea to check the voltages on this board as it is an early release, I would hate to see some one leak the factory installed smoke from a sensor.
Oh, Whit....don't bother driving there, I already bought everything at the store, shelves are empty now [noparse];)[/noparse]
Thank goodness rbdb bought them out.
There is free shipping on web order this weekend though...
Whit+
We just learned something important. rpdp has a sideline business now running over to Parallax for us?
Please see the thread I started about Fire and smoke.
