Unintentional Theramin...
Hugh
Hi,
I have a Protoboard with the Prop connected to an LCD, an SD card and three switches. Each switch brings a Prop pin to ground when pressed - otherwise pull-up resistors keep the pins high. Today I noticed that one of the switches appears to activate if I hold my hand near the protoboard (the number on the LCD counts down as it should if the switch is pressed). As part of troubleshooting I cut the wire close to the protoboard but it still happens.
The other switches/pins are unaffected and a 0.1uF capacitor soldered from the Prop-pin to gnd didn't make any difference. There are quite a few long messy wires (it is a ptototype!) but its got me stumped. Any thoughts?
Hugh
Hugh - the thinking woman's Geoffrey Pyke.
Hugh
I notice that the Prop ccts always seem to favour the pull-down res and the switch on the high side.
Style and grace : Nil point
The pull-up on that switch is either open or not connected to Vdd.
www.youtube.com/watch?v=WPZQi2m7i9Y
