propeller servo controller problem
Hi, new to the forum.· I hope this is the right place to post my question.
I have a possible problem with my propeller servo controller:·
The set up:
Im using a laptop with Windows XP
the device is a Propeller Servo Controller USB, item 28830
I'm using VSA for servo control
power: usb cable supplies power to the controller board; an atx computer supply, 5 volt rail, powers the servos
Problem:
mini servo motors attached to the board work fine (for example, T Pro SG90).· Larger servos, such as T Pro Sg 5010 or slightly smaller attached to board will not respond--they twitch and jitter but do not responde to routines.· I tested the servos with an E Sky servo tester and they work.
Via VSA the·baud rate is set at 38.4k
Bad board?· Bad settings somewhere?·Any ideas?
Any advice you can give would be welcome.
The set up:
Problem:
·http://forums.parallax.com/showthread.php?p=862005
I'll check back.
Jim
Jim
Can you do a sanity check for me and see if the Propeller Servo Controller will work at the lower 2400 baud default setting?
Beau Schwabe
IC Layout Engineer
hover1, thanks for the suggestion. I have a basic understanding, but really am just getting into all of this--and need to practice my soldering skills before I start adding components to a $40 circuit board!
Do you have a 6 volt or 7.2 volt battery to supply the servo power for a test? The specs on the servo say that it will take up to 8.4 volts.
Jim
Just in·case it helps any the board is item 28830 and has "Rev A" stamped on it.
Post Edited (Gumba) : 2/14/2010 4:19:00 PM GMT
From other posts I've seen this seems to be a real problem on the newer boards.· Do the folks at Parallax have a·plan on how to fix these boards?·
I have a plug·in board that I'm waiting to get from the manufacturer·that will add the resistors to all the outputs so I can run my JR Digital servos.
Jim
Post Edited (hover1) : 2/16/2010 2:19:13 AM GMT
Sorry if this is a dumb question.
You want to press F11, of course the usb cable must be connected and the board powered up.
Graham
Jim
Here is a test that I think will prove something, attach one of your small servos that works and one of the large servos that does not both at the same time.
If the small one works and the large doesn't then it is probably voltage level changing chips causing the problem. If neither work then most probably is is a supply problem, the larger servo putting noise on the line or dropping the voltage. In which case try an alternative supply.
Cheers,
Graham
Obviously the board needs some modifications. I'll check back to see what happens when you get the plug in board (from Parallax, I assume?). Maybe this is something they'll ship to others having a similar problem.
Sorry for the confusion, but I had some boards made myself, they do not come from Parallax. This is just to get me through a project that I have right now.
I think the whole resistor thing is just a bandaid right now until we get some some specs from Parallax as to what the output cababilities of the translators are, ie loads, impeadence, etc. It may be noise which has breen brought up before, and the resistor suppreses it. I'm not sure.
I'd be happy to help Parallax try and sort this out. I have a few animitronics projects based on this one board alone.
Jim
A difficult situation for them.
Graham
I think the ability to be bidirectional was going to turn the board into something by far more usefull than the old board. And it is. I use it to input PIR data to trigger servo actions. This saves me from having a·BOE for input and the PSC for output. It's a grand idea that I'm sure will be worked out by Parallax. (I know it could all be done on a Proto Board, but I need the small size).
I'm sure·if they spec'd it to be used only with the servos that they carry that would have precluded many sales. The old servo boards worked with many servos, but personally, I only started working with Digitals Servos on the new board, and that is when I started having problems.
Jim
Post Edited (hover1) : 2/21/2010 1:59:53 AM GMT
Graham
Initial price is $15.00 cheaper than the PSC, and I added $2.00 worth of components for·4-input/4-output version. A bandsaw and beltsander makes quick work of modifing the Proto Board. Less than 5 minutes.
Jim
