Made Your Own Monster Servo Lately? — Parallax Forums
ercoerco Posts: 20,263
edited 2010-02-14 02:03 in Robotics
I have a stockpile of·beautiful Pittman gearmotors, some with lots of gearing and serious torque. What a robot arm I could make out of them. After seeing the prices on the monster servos at https://www.servocity.com/html/spg785a-4_5_servo_gearbox.html·, I'm tempted to build·one myself by gutting a smaller servo for the electronics, adding a same-value potentiometer to my gearmotor and routing the pot & motor leads from the servo to the gearmotor. Just curious if anyone's·tried this·yet and how successful/stable they were.
  • WhitWhit Posts: 4,191
    edited 2010-02-11 03:03
    I have not tried this or seen it. It sure looks cool though!
    Whit+
    edited 2010-02-11 03:44
    My EE pals at work like my concept, but they warn that the current & voltage demands of a much larger motor will overwhelm the servo's original electronics. Fine, I can make a beefier H-bridge out of 4 power transistors or FETs and drive that with the servo's motor wires.
    Assuming that works, I can make a motor driver out of any continous rotation (or any, really) servo plus 4 transistors. Servos range in price, but there are some cheapies out there. In a thread a while back, someone provided a link to a site that sold micro servos for under $3. That's worth ordering a dozen servos and some experimental gutting.
    Now if I can just find that site!
  • Beau SchwabeBeau Schwabe Posts: 6,574
    edited 2010-02-11 04:21
    erco, if the search worked, I would point you to a cordless screwdriver mod I posted a few years ago...
    Edit:
    here is the link...
    http://forums.parallax.com/showthread.php?p=525689
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 2/11/2010 4:27:39 AM GMT
    edited 2010-02-11 04:51
    erco,
    Here's that link to the under $3 micro servo: http://www.hobbypartz.com/topromisesg9.html
    They have a lot of cheap servos of all sizes. Several under $10 and under $5.
    Check out the Propeller Wiki·and contribute if you can.
    edited 2010-02-11 05:32
    @Roy: Thanks, that's exactly the servo I remembered. You're on it, Pal!
    @Beau : DOH, Beau! As ever, you're several steps and years ahead of me. I'll check with you before posting my next "bright idea" and you can point me towards your fine body of pre-existing work. Ah well, at least my powers of reasoning pointed me in the right direction. Thanks for the cross-check and schematics, I do want to make some of these and get my 40 Pittman motors under control.
    edited 2010-02-11 08:57
    erco,
    thanks! ... in my cordless screwdriver mod, I mentioned fixing the original servo pot. You could just as easily mechanically link a pot (geared up/down, or the same) to the screwdriver and have a really big, very high torque servo.
    Beau Schwabe
    IC Layout Engineer
  • Tom CTom C Posts: 461
    edited 2010-02-11 17:21
    erco,
    I have made several monster servos using the VEX Robotics dc motors, a 5k/10k feedback pot, and the Lynxmotion servo driver board that can handle around 2 amps continuous. I have the VEX Robotics dc motors geared down by 40 to 1 and am using them to power the joints on my robotic arm. Works great.
    TCIII
    If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
  • P!-RoP!-Ro Posts: 1,189
    edited 2010-02-12 04:24
    To control large motors you could always use a relay. I was able to get 2 of them @ 44 cents each today at radioshack and they are rated for 5 amps. One of them is able to control motor direction and paired with a transistor can regulate speed.
    PG
    edited 2010-02-12 17:17
    @Pi Guy: Thanks, I love relays and use them all the time. I'm trying to break out of that habit. Making a servo-like action using relays requires at least 3 IO pins (2 motor plus 1 feedback pot) and constant monitoring. A real servo uses just one (add a servopal and there's no more constant monitoring), so I'm interested in making make giant servos out of affordable little ones.
    PS: TWO relays for 44 cents? Sign me up, you're winning me back over to the dark (relay) side! Which ones?
    @Tom: Also thanks for your input. I'm sure that Lynxmotion board can do it all. I just love re-inventing the wheel and trying to come up with cheap, clever workarounds.
    And I would have gotten away with it, too, it it wouldn't have been for that dang Beau Schwabe!
    He's already done ALL the good stuff! [noparse]:)[/noparse]
    edited 2010-02-13 23:24
    Beau Schwabe
    IC Layout Engineer
    It was 44 cents each, a little over a dollar for two with tax. That was at 50% off, though [noparse];)[/noparse] Turns out its good to befriend RS employees, seems to turn out for the best sometimes. Especially since I had to go there again today due to shorted parts--and I got the same deal from someone else!
    PG
