Graphite and Conductivity
Just popping a random question out there:
I would appreciate any help.
For my science fair project, I tested how temperature affects the conductivity of graphite. I hypothesized that graphite would act the same as metals - better conductivity at low temperatures, less conductivity at higher temperatures. I reasoned that since·heat disrupts electron flow in metals, leading to higher electric resistance, the same should occur in graphite. Contrary to my hypothesis, I found that graphite conducts electricity better at higher temperatures, rather than at lower temperatures.
This is my question: How does temperature affect the molecular structure of graphite so that it conducts electricity better at higher temperatures?
http://www.allaboutcircuits.com/vol_1/chpt_12/6.html
http://en.wikipedia.org/wiki/Temperature_coefficient#Negative_temperature_coefficient
I think a better way to pose this question might be: Why does graphite have a negative temperature coefficient of resistance?
It probably has much to do with graphite's conduction band.
Check out the following links for ideas:
www.seas.upenn.edu/~chem101/sschem/conduction.html#graphite
Read about the conduction band model: en.wikipedia.org/wiki/Thermistor
en.wikipedia.org/wiki/Conduction_band
www.everyscience.com/Chemistry/Inorganic/Carbon/a.1189.php
hope that helps get you started,
Mark
Post Edited (ElectricAye) : 2/10/2010 4:49:48 PM GMT
