byte and one bit in the byte
I am wondering how to go about this. Say I have a byte "Numb" and I want to manipulate bit 6 in the byte.
for example:
Numb := %1111_0000
Now I want to make all the bits in Numb the same except bit 6.
Numb := %1011_0000
I would prefer to have 2 variables i.e. Numb and the NewNumb
NewNumb := %1
Numb := %11newNumb1_0000
I hope this makes since.
for example:
Numb := %1111_0000
Numb := %1011_0000
NewNumb := %1
EDIT: SORRY THIS IS GARBAGE FOR BYTES
Post Edited (Graham Stabler) : 2/10/2010 3:02:15 PM GMT
Bit indexing like that only works on SFR's.. If Numb was defined as a byte, that would write the byte at @Numb+6 instead.
Off the top of my head.. something like..
Numb := (Numb & !(1<<6)) | (NewNumb <<6)
.. might work
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should use WD40.
Post Edited (BradC) : 2/10/2010 1:56:28 PM GMT
Turn bit 6 on: numb |= |< 6
"numb or-equals bitwise-decode six"
Turn bit 6 off: numb &= ! |< 6
"numb and-equals bitwise-not bitwise-decode six"
I cant understand that stuff you put down localroger. Please give me a few more minutes and write down a little more details. I am even reading the propeller manual (bitwise decode) and I am lost. I guess its got something to do with me going to work at 2am.
It's really easy once you get your head around it..
(|< 6) would give you the same result of (1 << 6) but uses less code space and does it quicker.
In plain english, you give it a number between 0 & 31, and it gives you a long with only that particular bit set.
So to set the bit in a long, you would use xx |= |< bit
|< bit generates a long with only the single bit set, and or's it with the existing value (setting that bit unconditionally)
To unset the bit you would use xx &= ! |< bit
the ! |< bit generates the long with the single bit set, and the ! inverts it to create a long with all bits except that one set. If you and that with the original value, you get the original value without that bit set.
newVal := old Val "bitwise or" bit-pattern
You get the bit-pattern of a single bit by using |<x operation, where x is the number of the bit you want to set.
If you want to clear a bit, then you can use "bitwise and" where all bits are 1 except the one you want to clear.
new Val := old Val "bitwise and" with bit-pattern where bit to clear is 0
This bit-pattern can be generated by inverting the |<x, which is !|<x
localroger simply used the shortcut of assigning operators, which do the bitwise or/and of left and righthand operand and directly assign the result back to the lefthand-operand.
(|= and &=)
PS: I should switch off all interrupts, when answering posts ;o)
Post Edited (MagIO2) : 2/10/2010 2:36:22 PM GMT
No a byte is fine.
All operations in the spin interpreter are carried out as long. If you declare a byte, when the operation is written out, it is simply truncated down to the declared size.
This works because I can set any bit at any time then send it out to the serial to parallel IC.
A trivial change, based on localrogers concept above :
That would be marginally faster an a poofteenth smaller.
