ZPU Emulator needs help with mul, div, and mod.
I know this has been asked before, and by me, but could someone point me to some nice small arithmetic routines in PASM
for use in the ZPU emulator?
ZPU requires:
Multiplication of two 32 bit twos complement integers with a 32 bit result.
Multiplication of two 16 bit unsigned numbers with a 32 bit result.
Division of a 32 bit twos complement integer by another with a 32 bit result.
Modulus, as above.
ZPU requires:
Modulus, as above.
http://forums.parallax.com/showthread.php?p=731577
"a" holds the opcode (lower 5 bits as shown in the first block of code...·e.g. MPY=$F4=%10100)
"x" and "y" are the two numbers to be multiplied (or divided) x * y or x / y, result is in "x" (pushed).
So, if you use this routine with a set to...
·a = $F4 (multiply, return lower 32 bits),·= $F5 (multiply, return upper 32 bits), = $F6 (divide, return quotient 32 bits), = $F7 (divide, return remainder 32 bits)
But, only set the lower 5 bits meaning $F4 --> $14, etc to save the first and a/#%11111 instruction.
Hope this makes sense now
'$F4..F7 = MUL/DIV lower/upper result math_F4 and a,#%11111 '<== and mask (need in a) mov t1,#0 mov t2,#32 'multiply/divide abs x,x wc muxc a,#%01100 abs y,y wc,wz if_c xor a,#%00100 test a,#%00010 wc 'set c if divide (DIV/MOD) if_c_and_nz jmp #mdiv 'if divide and y=0, do multiply so result=0 shr x,#1 wc 'multiply mmul if_c add t1,y wc rcr t1,#1 wc rcr x,#1 wc djnz t2,#mmul test a,#%00100 wz if_nz neg t1,t1 if_nz neg x,x wz if_nz sub t1,#1 test a,#%00001 wz if_nz mov x,t1 jmp #push mdiv shr y,#1 wc,wz 'divide rcr t1,#1 if_nz djnz t2,#mdiv mdiv2 cmpsub x,t1 wc rcl y,#1 shr t1,#1 djnz t2,#mdiv2 test a,#%01000 wc negc x,x test a,#%00100 wc test a,#%00001 wz if_z negc x,y jmp #push▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
With those in place the ZPU is eating 321 LONG in COG. Only three little ops to do and the main fetch execute loop.
Looks like it will all fit in just fine.
At the moment the dispatch table is 256 bytes in HUB. I can use byte entries in the table as all the opcode handler routines can fit in the first half of the COG nicely.
All the ZPU memory accesses have been localized to a few functions so moving to external RAM should be painless.
Has anyone ever heard of an "Arithmetic Shift Left" ?
The ZPU docs have defined one and it exists in their Java simulator. In fact they document this with the Java code:
What's the idea here ?
Maybe they've done/named it to remain consistent with an ASR?
Life may be "too short", but it's the longest thing we ever do.
It's an awfully long winded way of specifying it.
- Tony
http://zuzebox.wordpress.com/
LSHIFTRIGHT 42 unsigned shift right. long shift; long valX; int t; shift = ((long) popIntStack()) & INTMASK; valX = ((long) popIntStack()) & INTMASK; t = (int) (valX >> (shift & 0x3f)); pushIntStack(t); ASHIFTLEFT 43 arithmetic(signed) shift left. long shift; long valX; shift = ((long) popIntStack()) & INTMASK; valX = ((long) popIntStack()) & INTMASK; int t = (int) (valX << (shift & 0x3f)); pushIntStack(t); ASHIFTRIGHT 43 arithmetic(signed) shift left. long shift; int valX; shift = ((long) popIntStack()) & INTMASK; valX = popIntStack(); int t = valX >> (shift & 0x3f); pushIntStack(t);So to my simple mind and zero understanding of any funky Java operator quirks this maps to PASM shifts as follows:
LSHIFTRIGHT => SHR
ASHIFTLEFT => SHL
ASHIFTRIGHT => SAR
ZyLin's naming of the SHL seems a little weird to me.
Here they are talking about a "...signed left shift operator..." which basically does not make any sense to me as there is only one type of left shift and it does not care about the sign. Unless of course unless Java sign extends a signed 16 bit short when shifting it left and assigning to a 32 bit int. Hence "arithmetic shift left".
I learned something new today. C is not guaranteed to use an arithmetic shift right for integers !
