MCP3301 ADC(single channel, 13 bit); no obex object.
Clock Loop
I downloaded and tried the 3201 object, but something is wrong and I am not sure what.
I don't have experience with comms to an ADC so i figured I would ask here if anyone has already done this chip.
I also don't yet have a scope that can help me in that task.
Anyone have a 3301 working with the prop?
I was dong audio stuff with it at about 19.5k so there are a stack of waitcnt in there to slow the sampling down. You don't have to run it that slow.
Ignore the rest of the code, it's doing all sorts of stupid things.
atod org 0 mov adc_c, cnt add adc_c, adc_cycles mov adc_fpos, par add adc_fpos, #4 mov dira, adc_dirval mov outa, #4 ' CS High, CLK Low mov adc_lta, #0 mov adc_sta, #0 mov adc_lfopos, par add adc_lfopos, #32 mov adc_filtered, #0 mov adc_divide, #4 :toploop or outa, adc_dbg neg adc_sample,adc_filtered wrlong adc_sample, par wrlong adc_frame, adc_fpos wrlong adc_lfo, adc_lfopos add adc_lfo, adc_lfoincr :loop waitcnt adc_c, adc_cycles {-- this bit samples the ADC --} andn outa, #4 ' CS Low mov adc_bl, cnt add adc_bl, adc_acq waitcnt adc_bl, adc_acq or outa, #1 ' Clk High waitcnt adc_bl, adc_acq andn outa, #1 ' CS Low waitcnt adc_bl, adc_acq or outa, #1 ' Clk High waitcnt adc_bl, adc_clk mov adc_sample, #0 mov adc_r1, #14 :bitloop andn outa, #1 ' Clk Low waitcnt adc_bl, adc_clk test adc_in, ina wz shl adc_sample, #1 muxnz adc_sample, #1 or outa, #1 ' Clk High waitcnt adc_bl, adc_clk djnz adc_r1, #:bitloop {-- END ADC SAMPLE --} andn outa, adc_dbg and adc_sample, adc_mask shl adc_sample, #19 sar adc_sample, #20 or outa, #4 andn outa, #1 mov adc_r1, adc_sample subs adc_r1, adc_filtered sar adc_r1, #2 adds adc_filtered, adc_r1 djnz adc_divide, #:loop mov adc_divide, #4 add adc_frame, #1 jmp #:toploop adc_bias long $8000_0000 adc_acq long 40 adc_clk long 25 adc_dirval long %0101 + 1<<21 adc_cycles long 1023 adc_filtered long 1 adc_in long 1<<1 adc_frame long -60000 adc_mask long $1FFF adc_lfoincr long $6FFF adc_dbg long 1<<21 adc_fpos res 1 ' Pointer to HUB Frame variable adc_c res 1 ' Overall loop timer adc_bl res 1 adc_sample res 1 adc_old res 1 adc_new res 1 adc_lfo res 1 adc_lfopos res 1 adc_2sample res 1 adc_2old res 1 adc_2new res 1 adc_temp res 1 adc_sta res 1 adc_lta res 1 adc_divide res 1 adc_r1 res 1 adc_r2 res 1 adc_noisegate res 1 adc_noiseflag res 1 adc_lastsamp res 1 fit $1f0▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Life may be "too short", but it's the longest thing we ever do.
If you could dumb it down, add comment lines, it would be a great help for me.
Yeah, I'll try and clean it up and re-post it tomorrow for you. The code is dirty and ugly as I was trying all sorts of hacky stuff to get a clean audio signal.
Heres what i have so far, many redundant lines right now, till i change them into what they really are.
DAT ' ASSEMBLY org 0 'reset assembly pointer, this is register 0 atod 'asm address name mov adc_c, cnt 'Current 32-bit System Counter value written to adc_c 4 clocks add adc_c, adc_cycles 'add adc cycles to system count. 4 clocks mov adc_fpos, par 'MOV Destination, <#>Value 'Set register to a value. 4 clocks Par = Cog Boot Parameter register. add adc_fpos, #4 'ADD Value1, <#>Value2 'Add unsigned values. 4 clocks mov dira, adc_dirval 'MOV Destination, <#>Value 'Set register to a value. 4 clocks mov outa, #4 'MOV Destination, <#>Value 'Set register to a value. 4 clocks 'CS High, CLK Low mov adc_lta, #0 'MOV Destination, <#>Value 'Set register to a value. 4 clocks mov adc_sta, #0 'MOV Destination, <#>Value 'Set register to a value. 4 clocks mov adc_lfopos, par 'MOV Destination, <#>Value 'Set register to a value. 4 clocks Par = Cog Boot Parameter register. add adc_lfopos, #32 'ADD Value1, <#>Value2 'Add unsigned values. 4 clocks mov adc_filtered, #0 'MOV Destination, <#>Value 'Set register to a value. 4 clocks mov adc_divide, #4 'MOV Destination, <#>Value 'Set register to a value. 4 clocks :toploop 'asm address name or outa, adc_dbg 'OR Value1, <#>Value2 'Bitwise OR values. 4 clocks neg adc_sample, adc_filtered 'NEG NValue, <#>SValue 'Get negative of a number. 4 clocks wrlong adc_sample, par 'WRLONG Value, <#>Address 'Write long to main memory. 7 to 22 clocks wrlong adc_frame, adc_fpos 'WRLONG Value, <#>Address 'Write long to main memory. 7 to 22 clocks wrlong adc_lfo, adc_lfopos 'WRLONG Value, <#>Address 'Write long to main memory. 7 to 22 clocks add adc_lfo, adc_lfoincr 'ADD Value1, <#>Value2 'Add unsigned values. 4 clocks :loop 'asm address name waitcnt adc_c, adc_cycles 'WAITCNT Target, <#>Delta 'Pause execution temporarily. 5 clocks + {-- this bit samples the ADC --} andn outa, #4 'ANDN Value1, <#>Value2 'Bitwise AND value with NOT of another. 4 clocks ' CS Low mov adc_bl, cnt 'MOV Destination, <#>Value 'Set register to a value. 4 clocks add adc_bl, adc_acq 'ADD Value1, <#>Value2 'Add unsigned values. 4 clocks waitcnt adc_bl, adc_acq 'WAITCNT Target, <#>Delta 'Pause execution temporarily. 5 clocks + or outa, #1 'OR Value1, <#>Value2 'Bitwise OR values. 4 clocks ' Clk High waitcnt adc_bl, adc_acq 'WAITCNT Target, <#>Delta 'Pause execution temporarily. 5 clocks + andn outa, #1 'ANDN Value1, <#>Value2 'Bitwise AND value with NOT of another. 4 clocks ' CS Low waitcnt adc_bl, adc_acq 'WAITCNT Target, <#>Delta 'Pause execution temporarily. 5 clocks + or outa, #1 'OR Value1, <#>Value2 'Bitwise OR values. 4 clocks ' Clk High waitcnt adc_bl, adc_clk 'WAITCNT Target, <#>Delta 'Pause execution temporarily. 5 clocks + mov adc_sample, #0 'MOV Destination, <#>Value 'Set register to a value. 4 clocks mov adc_r1, #14 'MOV Destination, <#>Value 'Set register to a value. 4 clocks :bitloop 'asm address name andn outa, #1 'ANDN Value1, <#>Value2 'Bitwise AND value with NOT of another. 4 clocks ' Clk Low waitcnt adc_bl, adc_clk 'WAITCNT Target, <#>Delta 'Pause execution temporarily. 5 clocks + test adc_in, ina wz 'TEST Value1, <#>Value2 'Bitwise AND values to affect flags only. 4 clocks shl adc_sample, #1 'SHL Value, <#>Bits 'Shift value left by specified number of bits. 4 clocks muxnz adc_sample, #1 'MUXNZ Destination, <#>Mask 'Set discrete bits of value to state of !Z. or outa, #1 'OR Value1, <#>Value2 'Bitwise OR values. 4 clocks ' Clk High waitcnt adc_bl, adc_clk 'WAITCNT Target, <#>Delta 'Pause execution temporarily. 5 clocks + djnz adc_r1, #:bitloop 'DJNZ Value, <#>Address 'Decrement value and jump to address if not zero. 4 or 8 clocks {-- END ADC SAMPLE --} andn outa, adc_dbg and adc_sample, adc_mask shl adc_sample, #19 sar adc_sample, #20 or outa, #4 andn outa, #1 mov adc_r1, adc_sample subs adc_r1, adc_filtered sar adc_r1, #2 adds adc_filtered, adc_r1 djnz adc_divide, #:loop mov adc_divide, #4 add adc_frame, #1 jmp #:toploop adc_bias long $8000_0000 adc_acq long 40 adc_clk long 25 adc_dirval long %0101 + 1<<21 adc_cycles long 1023 'this would be adc_filtered long 1 adc_in long 1<<1 adc_frame long -60000 adc_mask long $1FFF adc_lfoincr long $6FFF adc_dbg long 1<<21 adc_fpos res 1 '<Symbol> RES <Count> Reserve next long(s)of Cog RAM for symbol. ' Pointer to HUB Frame variable adc_c res 1 ' Overall loop timer adc_bl res 1 adc_sample res 1 adc_old res 1 adc_new res 1 adc_lfo res 1 adc_lfopos res 1 adc_2sample res 1 adc_2old res 1 adc_2new res 1 adc_temp res 1 adc_sta res 1 adc_lta res 1 adc_divide res 1 adc_r1 res 1 adc_r2 res 1 adc_noisegate res 1 adc_noiseflag res 1 adc_lastsamp res 1 fit $1f0 'FIT <Address> Validate previous instr/data fit below an address.
