Accidental Discovery : PVC Cleaner=PCB Cleaner
I was working on some cleanup of a PCB while I re-purposed it and discovered
a cleaner that worked better than my over-priced 99% alcohol, PVC pipe cleaner!
I happened to still have it on the workbench after doing some home repair last week.
Not only did it do a great job on clean up, but it left no residue behind! zero!
Cheap and effective!
OBC
New to the Propeller?
OBC
····www2.itap.purdue.edu/msds/detail.cfm?MSDSID=2830
····www2.itap.purdue.edu/msds/docs/7701.pdf
I've never had a problem using 'Isopropyl Rubbing Alcohol 70%' from my local grocery store. The other 30% is just water. Cost is 99 cents for a 16 ounce bottle.
Stay away from the MEK (that rhymes, so it's easy to remember). We used it as a "thinner' for epoxy paints and a cleaner around the 20mm gun ports on fighters in the Navy. It'll do bad stuff to your brain.
Duffer
Any technology, sufficiently developed, is indistinguishable from magic.· A.C. Clark(RIP)
The PCB itself doesn't dissolve unless its made of polymer plastic or has some plastic electronic parts on it.
I should be typing in Spin now.
Duffer
M.E.K. will soften up rubber.
Like the 21.5 inch wide mickeys on the back of a Hemi powered Hotrod.
I prefer Hoppes #9 powder solvent over M.E.K. But I wouldn't use ether on a circuit board.
Most PVC cleaners are labled cleaner/primer, and·leave a purple tint.
The Truth is out there············___$WMc%___···························· BoogerWoods, FL. USA
Post Edited ($WMc%) : 2/4/2010 2:47:03 AM GMT
Thanks for the heads up on MEK. I've been around (sealed!) cans of PVC pipe cleaner all my life
(Dad is a plumber, this might explain some things about dad.. "Just kidding, dad!" [noparse]:)[/noparse]
In spite of it all, the board I used the PVC cleaner on is working very well and it really did the trick.
I was soldering wires to coated (button points) contact points which needed to be scraped and
cleaned before I could make a connection.
OBC
Nice to hear you're alive & well, your deafening silence was quite ominous since your original post! Based on the many dangers and warnings listed here, I hoped you had not departed to the "big soldering station in the sky"!
Between Expo preparations and the Arcade Project I've been pretty loud.. [noparse]:)[/noparse]
That NES interface in the Arcade project (second video) is the one I used the PVC cleaner on.. Worked. [noparse]:)[/noparse]
OBC
Tracy Allen
www.emesystems.com
Wow, close call Microcontroller, that's why oily shop rags and drop clothes should go into a sealed container that every shop should have. http://wiki.answers.com/Q/Why_do_you_store_oily_rags_in_a_tightly_sealed_container
Even that old rag you use to wipe off your dipstick is a serious fire hazard in your garage/shop if not handled properly.
Duffer
extract:
Fire hazard - Oil soaked rags
Some paints cure by an auto-oxidative mechanism. In specific circumstances, such as when a large surface area of uncured product is confined to a small volume·and is in contact with air, this reaction can generate dangerous quantities of heat and lead to spontaneous combustion. Examples of such circumstances are balled-up cleaning rags; filters on spray booths and piles of semi-cured film scrapings or over-spray. Such waste should be disposed of under water to eliminate the hazard.
The products most at risk are any solventborne products, Resene Waterborne Smooth Surface Sealer and to a lesser extent Resene Waterborne Colorwood and Woodsman. The greatest danger exists with products with higher resin contents·as pigments tend to dilute and·dissipate the heat. Therefore the higher resin content Resene Qristal Clear Poly-Gloss has more potential danger than Resene Super Gloss, which in turn is worse than Resene Lusta-Glo. The inherent curing rate of the resin also impacts on the risk, which makes Resene HD Poly-Satin more prone than Resene Qristal Clear Poly-Satin.
In all cases, be aware that oil soaked rags may spontaneously generate heat and catch fire. Fully wash contaminated clothing as soon as possible and rinse impregnated rags with detergent and water before safely disposing of them.
southwest freight elevator: "the big elevator next to the parking lot...". No MSD literature, no paint lockers, no planned maintenance programs. I think he'll be let go soon!
Duffer
