Propeller code for fuel metter
Hi, i want to buy a propeller just for making a device that will tell me how much
liters of gasoline my car eat's every 100Km.
I have a flow sensor that give me out 1140 pulses (hall sensor inside) for each gasoline liter. I know my circumference of my car wheel.
Can someone help me with a short code that will display the result on 16x2 serial LCD please?
Jim
Depending on the vehicle, you should be able to pick a speed pulse going to the dash. This would the best. It's normally a 0-12v or 0-5v signal and could be read by the propeller.
I've also used the Fuel Injector pulses to keep track of the amount of fuel used.
Jim Fouch
FOUCH SOFTWARE
There you have all the info my interface can read...
