Proposed method of LMM for PropBASIC. Comments requested.
Bean
Before everyone gets all fired-up...LMM will not be in PropBASIC until AFTER the inital release. There are too many potential bugs.
But I was cleaning up the compiler code and though I'd better at least get an idea of how I am going to implement it.
So here is my version of LMM.
I have about zero experience with LMM, so I'd like some comments from member who have used it.
I have unrolled the execute loop 4 times, I know I could go further but I want to save as much space as possible for variables.
This code seems to work fine. You can copy and paste the main body of the code many times (past the 496 instruction limit) and it will still work.
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
Post Edited (Bean) : 2/5/2010 6:21:04 PM GMT
'' *** COMPILED WITH PropBasic VERSION 00.00.79 Feb 3, 2010 ***
CON 'DEVICE P8X32A, XTAL1, PLL16X
_ClkMode = XTAL1 + PLL16X
_XInFreq = 5000000 'FREQ 80_000_000
' LEDS PIN 23..16 LOW 'LEDS PIN 23..16 LOW
' Delay SUB 1 'Delay SUB 1
PUB __Program 'PROGRAM Start LMM
__OFFSET := @__Init
CogInit(0, @_LMM_Entry, @__DATASTART)
DAT
org 0
__Init
mov dira,__InitDirA
mov outa,__InitOutA
jmp #_LMM_JUMP
long @Start - @__Init
Start 'Start:
mov __temp1,#255 ' LEDS = 255
shl __temp1,#16
and __temp1,LEDS
andn outa,LEDS
or outa,__temp1
mov __param1,#100 ' Delay 100
jmp #_LMM_CALL
long @Delay_ret - @__Init
long @Delay - @__Init
mov __temp1,#0 ' LEDS = 0
shl __temp1,#16
and __temp1,LEDS
andn outa,LEDS
or outa,__temp1
jmp #_LMM_CALL
jmp #_LMM_JUMP ' GOTO Start
mov __temp1,#0 'END
waitpne __temp1,__temp1
Delay 'SUB Delay
mov __temp1,cnt ' PAUSE __param1
adds __temp1,_1mSec
mov __temp2,__param1
mins __temp2,#1 WC
__L0001
IF_NC waitcnt __temp1,_1mSec
IF_NC djnz __temp2,#_LMM_JUMP
long @__L0001 - @__Init
rdlong __PC,__PC 'ENDSUB
Delay_ret
long 0-0
DAT
'LMM Execution code
ORG 0
_LMM_Entry
mov __PC,__OFFSET
_LMM_LOOP
rdlong __INSTR1,__PC
add __PC,#4
__INSTR1
nop ' Placeholder for LMM instruction
rdlong __INSTR2,__PC
add __PC,#4
__INSTR2
rdlong __INSTR3,__PC
add __PC,#4
__INSTR3
rdlong __INSTR4,__PC
add __PC,#4
__INSTR4
jmp #_LMM_LOOP
_LMM_JUMP
rdlong __PC,__PC
add __PC,__OFFSET
jmp #_LMM_LOOP
_LMM_CALL
rdlong __temp1,__PC
add __temp1,__OFFSET
add __PC,#8
wrlong __PC,__temp1
sub __PC,#4
rdlong __PC,__PC
add __PC,__OFFSET
jmp #_LMM_LOOP
' Variables for LMM execution code
__OFFSET LONG 0-0' Set by spin
__PC LONG 0 ' Program counter
__InitDirA LONG %00000000_11111111_00000000_00000000
__InitOutA LONG %00000000_00000000_00000000_00000000
_1mSec LONG 80000
LEDS LONG 255 << 16
_FREQ LONG 80000000
__remainder
__temp1 RES 1
__temp2 RES 1
__temp3 RES 1
__temp4 RES 1
__temp5 RES 1
__param1 RES 1
__param2 RES 1
__param3 RES 1
__param4 RES 1
__paramcnt RES 1
FIT 492
CON
LSBFIRST = 0
MSBFIRST = 1
MSBPRE = 0
LSBPRE = 1
MSBPOST = 2
LSBPOST = 3
DAT
__DATASTART
Bean
Using an LMM macro jump vector table will simplify things and allow you to use
the same kernel regardless of where the LMM macros are implemented.
The downside is using longs for the table and slightly delayed execution.
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler Largos - upcoming nano operating system
Bean
A few months ago I was pretty chuffed when I compiled a C and a Basic program on the Zicog, and after compilation both returned a "40kb free" message. More than the memory on the propeller. Then RossH goes and blows that out of the water with ten times that. And now PropBasic is heading the same way. I am *very* impressed.
The code looks great. Speed is not a big issue ('tis now as it ever was, use assembly for speed), but the ability to start writing a program and to keep writing and keep writing and never worry about running out of space, well that is just awesome.
· PropBASIC LMM is not virtual memory. It runs from HUB ram, so programs are still limited to 32K. But that is a far cry from 2K. Also lots of room for variables with LMM.
· Speed is about 1/5 of native code. I think that is a fair trade-off. Code with lots of calls and jumps will suffer most, but will still be·blazing compared to spin.
· You will be able to specify LMM for the main code, and for each TASK. So some tasks can be native (for video drivers and stuff) and some can be LMM within the same program.
· Actually for small TASKs it takes less space to make them native. I think very few TASKs will be LMM, but I wanted to have the option.
· I ran into an issue using VAR arrays. I use MOVS and MOVD to do indexing, well that doesn't work in LMM. So I had to make two more LMM routines to handle it.
· I'm going through the compiler and making the changes to handle LMM. I may post it for some testing, but NOT as the offical beta version.
· Once you get your head around it, LMM isn't that hard. I hope the LMM code generated will provide assistance to PropBASIC users who want to do LMM in assembly.
· Thanks for the encouragement.
Bean.
Post Edited (Bean) : 2/6/2010 4:32:32 AM GMT
I'm looking at my code at the moment and thinking maybe it could be ported to propbasic?
Thats not "awesome" its "Microsoft"
Style and grace : Nil point
Bean.
during my experiments with PropBasic I have seen, that you can do really very much without LMM and you have got full speed.
So I am very glad to read, that there will be the choice for each task if this task will run in the cog only or with LMM!
Is there a chance to include some sort of debugging feature into the LMM? It should be possible to insert debugging steps between program parts?
Perhaps you could install some sort of a "hook" for a debugger routine,·that can be called after each basic line. This debugger routine could be done later.
The debugger routine might copy a source code line number and all cog variables to hub ram. A debug task might then send the information to a serial line.
The hook could perhaps be used for some sort of polled interrupts too?
I think, that debugging features are often·very valuable, perhaps more valuable then execution speed.
(I would like to have multi line comments too...)
Christof
Just to give you some idea of speed:
PASM instructions without jumps require 20 clocks (on average), 3 instructions require 16 clocks, then the·4th requires 32 clocks.
Jumps require 32 clocks. Calls require 96 clocks.
So code with alot of jumps and calls do take a real performace hit.
Bean.
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
Post Edited (Bean) : 2/11/2010 7:29:27 PM GMT
