MemoryBlade & LatchBlade: 512KB SRAM & Latch pcbs for the Propeller Proto Board — Parallax Forums
Cluso99Cluso99 Posts: 18,071
edited 2010-02-08 11:41 in Propeller 1
Here is a preview of 2 pcbs I anticipate sending to manufacture over the weekend.
MemoryBlade:
  • 1.3"x1.3" 1.2"x1.2" (30.5mmx30.5mm) SMT pcb
  • Stacks onto·the Propeller Proto Board using the centre row of holes around the propeller chip
  • Contains
    • 512KB 55nS SRAM (SMT)
    • microSD socket
    • decoupling capacitors and pullup resistors
  • Adds SRAM & microSD to the Propeller Proto Board to make it like a RamBlade
  • Propeller pin requirements
    • 8 pins for D0-7
    • 16 pins for A0-15 (64KB SRAM)
    • optional 3 pins for A16-18 (128KB/256KB/512KB SRAM)
    • 3·pins (1·discounting SCL & SDA)·for -CS, -CE, -WE (-CS & -WE can be shared with Eeprom SCL & SDA
  • So for a 64KB SRAM design·(including microSD)·27 pins (25) are required while a 512KB design requires 30 pins·(28)·
  • With the addition of the LatchBlade pcb stacked between the Propeller Proto Board and MemoryBlade
    • a 64KB latched SRAM design·(including microSD)·requires only 11 pins··(9 discounting SCL & SDA) while a 512KB design requires·14 pins (12)
LatchBlade:
  • Stacks between the Propeller Proto Board and Memory Blade pcb to convert the MemoryBlade to a latched memory version
  • Contains
    • 74LVC573 DIP SMT·to latch A0-7 from D0-7
    • 74LVC573 DIP SMT·to latch A8-15 from D0-7
    • 74LVC86 SMT to drive the latches from 1 propeller pin
      • 8 pins for D0-7
      • ·4 ·3·pins for· -CS, -CE, ·CS, -WE, LE (latch) (CS & LE can be shared with Eeprom SCL & SDA)
      • optional 3 additional pins for A16, A17, A18 for 128KB/256KB/512KB (else 64KB)
    • resistors and capacitors
  • So for a 64KB SRAM design·(including microSD)·only 11 pins·(9 discounting SCL & SDA)·are required while a 512KB design requires·14 pins (12)
The design is stackable, so it is possible to change the configuration by adding/removing the LatchBlade. Stack height will be approx·13.6mm between pcbs (15.2 top to top).
The MemoryBlade will be available fully assembled or as a kit for those who want to try their hand at smt (no responsibility taken).
The LatchBlade will be available·fully assembled, partly assembled (smt only) or as a kit for those who want to try their hand at smt.
The SMT ICs are 0.05" (1.27mm) pitch which is fairly easy to hand solder with a fine soldering iron.
Estimated cost fully assembled US$12-18 for the pair (not each) including shipping·unregistered AirMail.
Block Diagram...
Post Edited (Cluso99) : 2/8/2010 5:59:21 AM GMT
