Prop portable binary programmer
I have not been able to find a small compiler that I can offer my customers to use in the field. I need to re-program a unit and the customer needs something to load my new binary code into the propeller.
Any ideas...
Thanks in advance
Any ideas...
Thanks in advance
Leon
Amateur radio callsign: G1HSM
Leon
·http://www.parallax.com/ProductInfo/Microcontrollers/PropellerGeneralInformation/PropellerDownloads/PropellentLibraryandExecutable/tabid/650/Default.aspx
Jim
Any ideas?
(Syntax Definitions: Propellent.exe {/LIB lib_path} {/PORT (AUTO | COM#)} {/SIGNAL (DTR | RTS | BOTH)} {/GUI (ON | STATUS | DIALOGS | OFF)} {/EEPROM} propeller_file {>message_file} – Load source/image and download to Propeller chip.UPDATE:
Maybe a small batch file to copy your update to the customer computer. A zipped file would contain Propellent.exe, your .eeprom file, and a batch file (call it update.bat).
the batch file would contain:
Create a new directory and unzip your files there. Then click on update.bat.
I'm assuming the USB drivers are already loaded, so propellant can find the port.
Post Edited (hover1) : 2/5/2010 5:17:19 PM GMT
