Is it normal to have to at $10 to labels when using LMM ?
Bean
I have been working on my implementation of LMM, but it seems I must add $10 to all the labels.
I tried using ORG $10, but that didn't work either.
I wanted to implement CALL the same way the propeller does (where it changes the return instruction).
Anyway by putting in a bunch of LONG values I was able to see that all the "LONG @label" values where off by $10 but I don't know why.
Is there an easier way to do this without having to add $10 all the time ?
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
''*************************************** ''* Propeller LMM Experiments * ''* Author: Terry Hitt * ''*************************************** CON _ClkMode = xtal1 + pll16x _XInFreq = 5_000_000 PUB Main CogNew(@_LMM_Entry, @My_LMM_Code) DAT ORG $0 ' ------------------------------------------------------------------------------------------- ' LMM Program ' ------------------------------------------------------------------------------------------- My_LMM_Code or DIRA,Mask ' Make pin an output mov Wait,CNT ' Setup wait variable add Wait,Delay Again or OUTA,Mask jmp #_LMM_CALL ' call #Pause LONG @Pause_RET + $10 LONG @Pause + $10 andn OUTA,Mask jmp #_LMM_CALL ' call #Pause LONG @Pause_RET + $10 LONG @Pause + $10 rdlong _LMM_PC,_LMM_PC ' jmp #Again LONG @Again + $10 ' Subroutine Pause Pause waitcnt wait,delay rdlong _LMM_PC,_LMM_PC Pause_RET LONG 0-0 DAT ' ------------------------------------------------------------------------------------------- ' LMM Execution code ' ------------------------------------------------------------------------------------------- ORG 0 _LMM_Entry mov _LMM_PC,PAR _LMM_LOOP rdlong _LMM_INSTR1,_LMM_PC add _LMM_PC,#4 _LMM_INSTR1 nop ' Placeholder for LMM instruction jmp #_LMM_LOOP _LMM_CALL rdlong _LMM_TEMP,_LMM_PC add _LMM_PC,#8 wrlong _LMM_PC,_LMM_TEMP sub _LMM_PC,#4 rdlong _LMM_PC,_LMM_PC jmp #_LMM_LOOP ' Variables for LMM execution code _LMM_PC LONG 0 ' Program counter _LMM_TEMP LONG 0 ' Constants/Variables for My_LMM_Code Mask LONG %0000_0000_1111_1111_0000_0000_0000_0000 Delay LONG 40_000_000 ' Variables for My_LMM_Code Wait RES 1
Bean
Yes - this is quite normal. Calculating where your DAT segment actually ends up in the binary can be complex (and as far as I know, undocumented). There probably is a "proper" way to do it, but in Catalina I just use various constant values - the value $10 crops up quite a lot.
Ross.
Thanks Ross.
Post Edited (kuroneko) : 2/5/2010 3:07:56 AM GMT
The Spin compiler doesn't know where it's going to put the DAT section until after the code is compiled, so you either have to modify _LMM_CALL and _LMM_JUMP to use relative addresses or to add an offset that's set during the LMM initialization from the address of the start of the DAT section and all the jump and call addresses in the DAT section are relative to this offset. Homespun has another operator (@@@) that allows you to put absolute addresses into compiled constants, but the Propeller Tool doesn't have this and I'm not sure if BST has it.
$10 does seem to be the most likely error offset for DAT variables when I finally get SPIN to locate them directly.
I should look at the programs that use $10 to see if I ever found a rarely encountered fix.
An unelegant idea recently is to invent an unlikely LONG and search for it at the beginning of the spin.
PUB start_main_spin '***untested idea*** PDAT:=0 repeat until long[noparse][[/noparse]PDAT]==$D15C07EC" PDAT:=PDAT+1 ' now do something with BYTE[noparse][[/noparse]PDAT+something] DAT PDAT long $D15C07EC" 'true address of DAT to search for▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
I should be typing in Spin now.
So I figure the Loader actually subtracts $10 from every one of these address values when a program is put into a cog. It does seem a bit of a kludge to force asembly writers to add an offset that will get removed when the code is actually used·compiled*. We're probably stuck with that choice, which might not be a dimbulb moment. Perhaps Chip will explain.
By the way, is there a reference table to those initialization values? Page 31 just explains the first two. Answer: never mind. See http://propeller.wikispaces.com/Hub+Memory+Map
* I think the IDE's compiler forces these offsets.
Post Edited (Fred Hawkins) : 2/6/2010 4:24:36 PM GMT
Ariba or someone pointed out that if you don't like to have the magic number $10 in your code and are worried it may be different in different cases then the base offset can be got using @[noparse][[/noparse]0]. If I remember correctly.
I can't for the life of me understand how or why @[noparse][[/noparse]0] should work.
It forces the spin interpreter to give the hub address of byte 0 of the object.
Life may be "too short", but it's the longest thing we ever do.
