As with any problem, how about attaching your program source to your message. I would suggest you carefully go through the description in the documentation on sending e-mail and check to make sure each of the required steps is done in your program. I don't have my PINK documentation handy, but I remember a list of variables all of which have to be set up properly.
Mike you are right, I should have included it in my first post...
' File...... PINKSendEMail.bs2
' Purpose... Send Test E-Mail From PINK Module via BASIC Stamp 2
' Author.... Parallax, Inc.
' E-mail.... support@parallax.com
' Started...
' Updated... 09-10-2007
' {$STAMP BS2e}
' {$PBASIC 2.5}
' -----[noparse][[/noparse] Program Description ]---------------------------------------------
' This program demonstrates how to send e-mail using the PINK Module. You
' must replace the various data below with your actual addresses and server
' information before running this example. Once run the program will
' display a success or failure message. optional parameters can be omitted
' by commenting out the appropriate SEROUT line in the code. NOTE: Not all
' SMTP servers will be compatible with the PINK Module. It is up to the
' customer to make that determination. Parallax Tech Support cannot assist
' with mail server issues.
' -----[noparse][[/noparse] I/O Definitions ]-------------------------------------------------
RX PIN 14 ' Serial Receieve Pin --> PINK.TX
TX PIN 15 ' Serial Transmit Pin --> PINK.RX
' -----[noparse][[/noparse] Constants ]-------------------------------------------------------
Baud CON 396 ' 2400 bps (BS2)
' -----[noparse][[/noparse] Variables ]-------------------------------------------------------
nbvar VAR Byte ' PINK Data Variable
busy VAR nbvar.BIT2 ' E-Mail Busy Flag (Alias)
complete VAR nbvar.BIT4 ' E-Mail Complete Flag (Alias)
' -----[noparse][[/noparse] Program Code ]----------------------------------------------------
Main:
' Set TO Address
SEROUT TX, Baud, [noparse][[/noparse]"!NB0WET:support@bex.net", CLS]
' Set FROM Address
SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEF:*******@***.net", CLS] 'left blank to protect privacy
' Set SUBJECT
SEROUT TX, Baud, [noparse][[/noparse]"!NB0WES:Test Message From PINK", CLS]
' Set MESSAGE CONTENT
SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEC:testing 123", CLS]
' Set SMTP Server
SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEV:mail.bex.net", CLS]
' Set USERNAME (Optional On Some Servers)
SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEU:*******", CLS] 'left blank to protect privacy
' Set PASSWORD (Optional On Some Server)
SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEP:******", CLS] 'left blank to protect privacy
' Set AUTH ON/OFF (Optional On Some Servers)
SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEA:1", CLS] ' Turn Authentication On (Optional)
SEROUT TX, Baud, [noparse][[/noparse]"!NB0SM"] ' Command To Send E-Mail
DO
SEROUT TX, Baud, [noparse][[/noparse]"!NB0ST"] ' Send Command To Read Variable
SERIN RX, Baud, 1000, Timeout, [noparse][[/noparse]nbvar]' Get One Byte With Timeout
LOOP WHILE busy = 1
IF complete = 1 THEN
DEBUG CLS, "MAIL SENT SUCCESSFULLY!", CR
ELSE
DEBUG CLS, "MAIL SEND FAILURE!", CR
ENDIF
END
Timeout:
DEBUG "Communication Timeout!" ' Serial Timeout
END
Joshua, no this is the first time I have attempted to get the email feature to work, I contacted my ISP to provide the SMTP .Com info and later to see if it was an issue on their end. They got the same blank emails I was getting.
This is the same module I had issues with the password, your tech support put new firmware in and sent it back...Firmware Version: SB70 Parallax Web server 1.33
Ah, then I know which module you have. Let me see if I can set one up and duplicate the issue. I have not heard of any problems regarding the email and from what it looks like the syntax is all correct.
Hello,
I am having the same issue as Mike2545. Mail is sent, has a subject, but no message in the body. If I look in the header, the message is there. I am using the same mail program. The module is a PINK SB70 and I upgraded with the ParallaxR1p35_APP.s19 file.
AJ
Here is the code:
' Started...
' {$STAMP BS2}
' {$PBASIC 2.5}
' Serial Transmit Pin --> PINK.RX'
Temper VAR Word
Main:
HIGH 0
PAUSE 100
RCTIME 0, 1, Temper
' Set TO Address
SEROUT TX, Baud, [noparse][[/noparse]"!NB0WET:xxxxxx@xxxxxxx.xxx", CLS]
' Set FROM Address
SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEF:xxxxxx@xxxx.xxxxxx.xxx", CLS]
' Set SUBJECT
SEROUT TX, Baud, [noparse][[/noparse]"!NB0WES:Test Message", CLS]
SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEC:Temp is ",DEC Temper,CLS]
' Set SMTP Server
SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEV:xxxx.xxxxxx.xxx", CLS]
SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEU:xxxxxx", CLS]
SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEP:xxxxxx", CLS]
DO
LOOP WHILE busy = 1
ELSE
ENDIF
END
Timeout:
END
' ========================================================================= ' ' File...... PINKSendEMail.bs2 ' Purpose... Send Test E-Mail From PINK Module via BASIC Stamp 2 ' Author.... Parallax, Inc. ' E-mail.... support@parallax.com ' Started... ' Updated... 09-10-2007 ' ' {$STAMP BS2e} ' {$PBASIC 2.5} ' ' ========================================================================= ' -----[noparse][[/noparse] Program Description ]--------------------------------------------- ' This program demonstrates how to send e-mail using the PINK Module. You ' must replace the various data below with your actual addresses and server ' information before running this example. Once run the program will ' display a success or failure message. optional parameters can be omitted ' by commenting out the appropriate SEROUT line in the code. NOTE: Not all ' SMTP servers will be compatible with the PINK Module. It is up to the ' customer to make that determination. Parallax Tech Support cannot assist ' with mail server issues. ' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- RX PIN 14 ' Serial Receieve Pin --> PINK.TX TX PIN 15 ' Serial Transmit Pin --> PINK.RX ' -----[noparse][[/noparse] Constants ]------------------------------------------------------- Baud CON 396 ' 2400 bps (BS2) ' -----[noparse][[/noparse] Variables ]------------------------------------------------------- nbvar VAR Byte ' PINK Data Variable busy VAR nbvar.BIT2 ' E-Mail Busy Flag (Alias) complete VAR nbvar.BIT4 ' E-Mail Complete Flag (Alias) ' -----[noparse][[/noparse] Program Code ]---------------------------------------------------- Main: ' Set TO Address SEROUT TX, Baud, [noparse][[/noparse]"!NB0WET:support@bex.net", CLS] ' Set FROM Address SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEF:*******@***.net", CLS] 'left blank to protect privacy ' Set SUBJECT SEROUT TX, Baud, [noparse][[/noparse]"!NB0WES:Test Message From PINK", CLS] ' Set MESSAGE CONTENT SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEC:testing 123", CLS] ' Set SMTP Server SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEV:mail.bex.net", CLS] ' Set USERNAME (Optional On Some Servers) SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEU:*******", CLS] 'left blank to protect privacy ' Set PASSWORD (Optional On Some Server) SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEP:******", CLS] 'left blank to protect privacy ' Set AUTH ON/OFF (Optional On Some Servers) SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEA:1", CLS] ' Turn Authentication On (Optional) SEROUT TX, Baud, [noparse][[/noparse]"!NB0SM"] ' Command To Send E-Mail DO SEROUT TX, Baud, [noparse][[/noparse]"!NB0ST"] ' Send Command To Read Variable SERIN RX, Baud, 1000, Timeout, [noparse][[/noparse]nbvar]' Get One Byte With Timeout LOOP WHILE busy = 1 IF complete = 1 THEN DEBUG CLS, "MAIL SENT SUCCESSFULLY!", CR ELSE DEBUG CLS, "MAIL SEND FAILURE!", CR ENDIF END Timeout: DEBUG "Communication Timeout!" ' Serial Timeout END▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Mike2545
Mike2545
Have you ever gotten it to work before? Can you get the demo to work (see below)? In the IP Tool, what is the firmware version?
:Sample Snippet:
·SEROUT TX, Baud, [noparse][[/noparse]"!NB0WET:someone@somewhere.com", CLS]
·SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEF:PINK@parallax.com", CLS]
·SEROUT TX, Baud, [noparse][[/noparse]"!NB0WES:Test Message From PINK", CLS]
·SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEC:Message Content Goes Here!",CLS]
·SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEV:smtp.server.com", CLS]
·SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEU:username", CLS] ' (Optional)
·SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEP[noparse]:p[/noparse]assword", CLS] ' (Optional)
·SEROUT TX, Baud, [noparse][[/noparse]"!NB0WEA:1", CLS] ' Turn Authentication On (Optional)
·SEROUT TX, Baud, [noparse][[/noparse]"!NB0SM"] ' Command To Send E-Mail
:Sample End:
Respectfully,
Joshua Donelson
www.parallax.com
Regards
Mike2545
Respectfully,
Joshua Donelson
www.parallax.com
AJ
Here is the code:
' Started...
' {$STAMP BS2}
' {$PBASIC 2.5}
TX PIN 15
Temper VAR Word
Main:
HIGH 0
PAUSE 100
RCTIME 0, 1, Temper
' Set TO Address
' Set FROM Address
' Set SUBJECT
' Set SMTP Server
DO
LOOP WHILE busy = 1
ELSE
ENDIF
END
Timeout:
END
