Stepper motor drive + controller (wave sequency)
Hello, all;
This project use a H-Bridge Drive + BS2sx (controller) to drive a stepper motor.
Components:
1) Basic Stamp 2sx
Manufactory: http://www.parallax.com/
Datasheet: http://www.parallax.com/tabid/440/Default.aspx
2) Stepper motor
Manufactory: www.orientalmotor.com
Datasheet: http://catalog.orientalmotor.com/item/all-categories/pk-series-stepping-motors/pk243-01aa?&plpver=11&origin=keyword&filter=&by=prod
3) Mosfets, transistors, resistors, capaicitors
Bought from: http://www.mouser.com
a) Schematic:
b) Project code
c) Project picture 1
d) Project picture 2
e) Project video:·
http://www.youtube.com/v/kekL5DpTUP0&hl=en&fs=1
Thanks to Parallax team and all forum users,
OldSpring (Author of the project)
More projects at OldSpring Project Website:
http://oldspring.110mb.com
http://oldspring.nvdv.com
Post Edited (OldSpring) : 8/7/2008 8:03:09 PM GMT
Components:
1) Basic Stamp 2sx
2) Stepper motor
a) Schematic:
b) Project code
' File...... Stepper motor Drive + Controller
' Purpose... BS2sx + Step Motor + H-Bridge Drive
' Author.... OldSpring
' Email..... [url=mailto:OldSprings@yahoo.com]OldSprings@yahoo.com[/url]
' Started...
' Updated... 28 July 2008
' {$STAMP BS2sx}
' {$PBASIC 2.5}
' Wave sequence
' step 1 2 3 4
' +A x
' +B x
' -A x
' -B x
OUT1_A PIN 8
OUT2_A PIN 9
OUT1_B PIN 10
OUT2_B PIN 11
LOOP1 VAR Byte
SPEED VAR Byte 'Speed adjustment
LOW OUT1_A
LOW OUT2_A
LOW OUT1_B
LOW OUT2_B
Main:
FOR speed = 1 TO 9 STEP 3
'------------------- CW 360 degree --------------------
FOR LOOP1 = 0 TO 50
GOSUB STEP_CW
NEXT
PAUSE 100
'------------------ CCW 360 degree ----------------------
FOR LOOP1 = 0 TO 50
GOSUB STEP_CCW
NEXT
PAUSE 100
'------------------ CW 180 degree ---------------------
FOR LOOP1 = 0 TO 25
GOSUB STEP_CW
NEXT
PAUSE 100
'------------------ CCW 180 degree ---------------------
FOR LOOP1 = 0 TO 25
GOSUB STEP_CCW
NEXT
PAUSE 100
NEXT
'GOTO Main
END
'==================== Clockwise =====================
STEP_CW: ' CW 7.2 degree
GOSUB STEP10
PAUSE SPEED
GOSUB STEP11
PAUSE SPEED
GOSUB STEP12
PAUSE SPEED
GOSUB STEP13
PAUSE SPEED
RETURN
STEP10: ' CW 1.8 degree
HIGH OUT1_A '1
LOW OUT2_A '0
LOW OUT1_B '0
LOW OUT2_B '0
RETURN
STEP11: ' CW 1.8 degree
LOW OUT1_A '0
LOW OUT2_A '0
HIGH OUT1_B '1
LOW OUT2_B '0
RETURN
STEP12: ' CW 1.8 degree
LOW OUT1_A '0
HIGH OUT2_A '1
LOW OUT1_B '0
LOW OUT2_B '0
RETURN
STEP13: ' CW 1.8 degree
LOW OUT1_A '0
LOW OUT2_A '0
LOW OUT1_B '0
HIGH OUT2_B '1
RETURN
'================== Counterclockwise =========================
STEP_CCW: ' CCW 7.2 degree
GOSUB STEP00
PAUSE SPEED
GOSUB STEP01
PAUSE SPEED
GOSUB STEP02
PAUSE SPEED
GOSUB STEP03
PAUSE SPEED
RETURN
STEP00: ' CCW 1.8 degree
HIGH OUT1_A '1
LOW OUT2_A '0
LOW OUT1_B '0
LOW OUT2_B '0
RETURN
STEP01: ' CCW 1.8 degree
LOW OUT1_A '0
LOW OUT2_A '0
LOW OUT1_B '0
HIGH OUT2_B '1
RETURN
STEP02: ' CCW 1.8 degree
LOW OUT1_A '0
HIGH OUT2_A '1
LOW OUT1_B '0
LOW OUT2_B '0
RETURN
STEP03: ' CCW 1.8 degree
LOW OUT1_A '0
LOW OUT2_A '0
HIGH OUT1_B '1
LOW OUT2_B '0
RETURN
e) Project video:·
Interesting Project...one recommendation would be to make a larger version of the schematic available and try to make it clearer which lines are connected. From the low resolution version it seems that even the I/O pins from the BASIC Stamp are shorted together.
Chris Savage
Parallax Tech Support
