Stepping through a spin program line by line
I was using Ariba's PASD to do some PASM learning, I found the step feature to be the most helpful for me while I monitored the memory contents.
Is there any way to do this with a spin program? Does ViewPort do this?
Rick
PrEditor·- Text Editor
NYC Area Prop Club
Rick
NYC Area Prop Club
Yes, ViewPort let's you step through spin code- just like in Visual Studio. You can step into functions, step over them, or step out of a function. You can also set a breakpoint and have it run until it hits the breakpoint.
Hanno
Co-author of the official Propeller Guide- available at Amazon
Developer of ViewPort, the premier visual debugger for the Propeller (read the review here, thread here),
12Blocks, the block-based programming environment (thread here)
and PropScope, the multi-function USB oscilloscope/function generator/logic analyzer
And I see that as the top bullet point on the parallax page now.
I will download it and give it a go as I think it will really help me wrap up the loose ends in PrEditor.
Clusso,
Do I need to load a different Spin interpretter to use the one you mentioned?
Rick
NYC Area Prop Club
Yes, ViewPort can pause your program to let you view and change variables.
However, it also let's you monitor variables as the program is running, by graphing your data. There's a nice review in my signature... It also talks about the debugging features. I'll update my website soon- building new features is more fun than writing about them...
Here's the original thread about ViewPort's debugger: http://forums.parallax.com/showthread.php?p=760083
Hanno
I've been updating the wiki page with the latest detail I could find.
I am going to give SPUD a try as seems the best/only alternative.
NYC Area Prop Club
A decent number of people are running ViewPort under emulation (wine, Parallels) on OSX and Linux. Let me know if you need help setting that up.
CassLan,
Sorry to hear about your problem- sounds like it's related to a custom configuration string? You can create those with ViewPort's configuration wizard. Feel free to pm me for help...
Hanno
If you run into one of those ')' and '[noparse][[/noparse]' errors, save your code file and load it into the Parallax Prop tool and update the compile.
It will tell you exactly where (or if) the error is.
When you go back to ViewPort, all is well.
Jim-
Signature space for rent!
Send $1 to CannibalRobotics.com.
Under WINE? Really? That might be interesting. More information please.
Life may be "too short", but it's the longest thing we ever do.
