What's a good instrumentation op-amp?
I am trying to get about 500 to 1000 gain in a low noise opamp,· probably 1khz or less. What should I be looking for?
- Stephen
- Stephen
Here is a comparison of a couple of Linear Tech op amps, one for low impedance sources and one for high impedance work
LT1028 (bipolar) GBW=75 MHz, en=1 nV/rtHz at 1 kHz, in= 1 pA/rtHz
LTC6244 (cmos) GBW=50 MHz, en=8 nV/rtHz at 1 kHz, in= 0.6 fA/rtHz
(nano: 10-9) (pico: 10-12) (femto: 10-15) (rtHz: square root Hertz) (GBW: gain bandwidth)
Lots of specs define an op amp--That is why their data sheets are so long and confusing! Of course you have to clarify how low a noise your application really needs based on the signal source impedance and its intrinsic noise level. But you do probably need the GBW, 1 MHz certainly, better 10 or 20 MHz.
Tracy Allen
www.emesystems.com
