need more dimensions in microSDCard Adapter data sheet
Timothy D. Swieter
I was browsing the microSDCard adapter data sheet. I see the dimension drawing on page 3 doesn't have all teh deatils need to make a PCB for plugging in this module. I am thinking of a PCB with a socket for the SIP and two holes to match. Can Parallax add dimensions to show the center line of the SIP and the hole centers from the board edge for the two mounting holes?
This is the data sheet I was looking at: www.parallax.com/Portals/0/Downloads/docs/prod/acc/32312-microSDCardAdapter-v1.0.pdf
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
www.tdswieter.com
- Stephen
www.tdswieter.com
