Program Problem?
jknightandkarr
I got my Propeller wired up to numeric LED displays & tried it using Seven-segment Test.spin found here on the object exchange.
obex.parallax.com/objects/142/
and all I get is odd ball displays. Looks to me they are jarbled up. So I tried a simple test program to run through all my digits one at a time, displaying 0 to 9, & ending with the Decimal Points flashing back & forth before restarting to test my wiring job. The program displayed exactly what I wanted, so I assume it's problem with the seven segment program i downloaded. What part I don't know I've tried a few things & so far nothing fixes it. I got my segment/digit information, namely
directly from the SevenSegment.spin file, modified the DigSel to take it to 4 digits in my test program, so I know that's not the problem with the Seven-segment Test.spin I tried to use only the SevenSegment.spin & added my I/O pin usage information, a value to display, adjust config values as needed & get nothing but a blank display, so neither program is working correctly for me. If someone can help me figure this out, I'd be greatfulll, because I'm confused.
Joe
I'm going insaine. It's SOOOOOO much fun. lol
DAT
'Common cathode 7-segment displays are activated by bringing the cathode to ground
DigSel byte %1110
byte %1101
byte %1011
byte %0111
Digit0 byte %00111111
Digit1 byte %00000110
Digit2 byte %01011011
Digit3 byte %01001111
Digit4 byte %01100110
Digit5 byte %01101101
Digit6 byte %01111101
Digit7 byte %00000111
Digit8 byte %01111111
Digit9 byte %01100111
Joe
Well the code is the same as in the object actually, it remains basically unchanged but I'll add it.
{Demo program for SevenSegment object.} CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 lowDigit =8 'Low digit cathode digits = 4 'Number of digits to display Segment0 = 0 'Segment start pin VAR long counter OBJ sevenseg : "SevenSegment" PUB Start sevenseg.start(lowDigit, digits, Segment0, true) counter := 0 repeat sevenseg.SetValue(counter++) if (counter / 10 // 10) == 0 sevenseg.disable 'disable the display when the second digit is 0 else sevenseg.enable waitcnt(clkfreq/10 + cnt) sevenseg.SetValue(99){{General purpose Seven-segment display object. Can control from one to eight digits. Author: Steve Nicholson Version: 1.0 (4 Jan 2007) Email: ssteve@mac.com Copyright: none }} VAR long LowDigitPin, HighDigitPin 'The pins for specifying digits. ' Must be contiguous ' HighDigitPin can be from 0 to 7 more than LowDigitPin long Seg0Pin, Seg8Pin 'The pins for the segments. ' Must be contiguous ' Segment 8 is the decimal point long flags long myStack[noparse][[/noparse]10] long runningCogID long myValue CON isEnabled = %0001 PUB Start(dLow, digits, s0, enabled) '' Start the display '' Parameters: '' dLow - the pin number of the least significant digit '' digits - the number of digits to display (up to 8) '' s0 - the pin number of segment 0 '' enabled - the initial enabled state myValue := 0 LowDigitPin := dLow HighDigitPin := dLow + ((digits - 1) <# 7) 'Limit to eight digits Seg0Pin := s0 Seg8Pin := s0 + 7 dira[noparse][[/noparse]Seg0Pin..Seg8Pin]~~ 'Set segment pins to outputs dira[noparse][[/noparse]LowDigitPin..HighDigitPin]~~ 'Set digit pins to outputs outa[noparse][[/noparse]Seg0Pin..Seg8Pin]~ 'Turn off all segments dira[noparse][[/noparse]LowDigitPin..HighDigitPin]~~ 'Turn off all digits if enabled 'Set initial enabled state flags |= isEnabled else flags~ stop runningCogID := cognew(ShowValue, @myStack) + 1 PUB Stop '' Stop the display if runningCogID cogstop(runningCogID~ - 1) PUB Enable '' Enable the display flags |= isEnabled PUB Disable '' Disable the display flags &= !isEnabled PUB SetValue(theValue) '' Set the value to display myValue := theValue PRI ShowValue | digPos, divisor, displayValue ' ShowValue runs in its own cog and continually updates the display dira[noparse][[/noparse]Seg0Pin..Seg8Pin]~~ 'Set segment pins to outputs dira[noparse][[/noparse]LowDigitPin..HighDigitPin]~~ 'Set digit pins to outputs repeat if flags & isEnabled displayValue := myValue 'take snapshot of myValue so it can't be changed ' while it is being displayed divisor := 1 'divisor is used to isolate a digit to display repeat digPos from 0 to HighDigitPin - LowDigitPin 'only display as many digits as there are pins outa[noparse][[/noparse]Seg8Pin..Seg0Pin]~ 'clear the segments to avoid flicker outa[noparse][[/noparse]HighDigitPin..LowDigitPin] := byte[noparse][[/noparse]@DigSel + digPos] 'enable the next digit outa[noparse][[/noparse]Seg8Pin..Seg0Pin] := byte[noparse][[/noparse]@Digit0 + displayValue / divisor // 10] 'display the digit waitcnt (clkfreq / 10_000 + cnt) 'the delay value can be tweaked to adjust ' display brightness divisor *= 10 else outa[noparse][[/noparse]HighDigitPin..LowDigitPin]~~ 'disable all digits waitcnt (clkfreq / 10 + cnt) 'wait 1/10 second before checking again DAT 'Common cathode 7-segment displays are activated by bringing the cathode to ground DigSel byte %11111110 byte %11111101 byte %11111011 byte %11110111 byte %11101111 byte %11011111 byte %10111111 byte %01111111 Digit0 byte %00111111 Digit1 byte %00000110 Digit2 byte %01011011 Digit3 byte %01001111 Digit4 byte %01100110 Digit5 byte %01101101 Digit6 byte %01111101 Digit7 byte %00000111 Digit8 byte %01111111 Digit9 byte %01100111Joe
Did you wire it up by yourself (breadboard or prototyping PCB) or is it this big propeller board?
In the first case you maybe wired it differently than expected by the program? The digit pins should switch a transistor to ground when pin is low. The segment pins are high when the segment shoult light up. If the digit part is wrong then two things can happen:
The digit is usually "on" and only one of the 4 digits is off (if the transistor switches in the wrong case - output = 1) or you have a reversed display (the segments which are off show the number) in case your transistor is connected to supply voltage instead.
Joe
Without seeing the complete code it is guessing in the fog
best regards
Stefan
My codes i used are on the object exchange.
I really didn't modify it, other then dabble with come things & nothing worked, so non of that was saved.
I think its one or the other. I don't think there's both on the same chip. My leds are all Common Cathode.
Joe
PRI ShowValue | digPos, divisor, displayValue ' ShowValue runs in its own cog and continually updates the display dira[noparse][[/noparse]Seg0Pin..Seg8Pin]~~ 'Set segment pins to outputs dira[noparse][[/noparse]LowDigitPin..HighDigitPin]~~ 'Set digit pins to outputs repeat if flags & isEnabled displayValue := myValue 'take snapshot of myValue so it can't be changed ' while it is being displayed divisor := 1 'divisor is used to isolate a digit to display repeat digPos from 0 to HighDigitPin - LowDigitPin 'only display as many digits as there are pins outa[noparse][[/noparse]Seg8Pin..Seg0Pin]~ 'clear the segments to avoid flicker outa[noparse][[/noparse]HighDigitPin..LowDigitPin] := byte[noparse][[/noparse]@DigSel + digPos] 'enable the next digit outa[noparse][[/noparse]Seg8Pin..Seg0Pin] := byte[noparse][[/noparse]@Digit0 + displayValue / divisor // 10] 'display the digit waitcnt (clkfreq / 10_000 + cnt) 'the delay value can be tweaked to adjust ' display brightness divisor *= 10 else outa[noparse][[/noparse]HighDigitPin..LowDigitPin]~~ 'disable all digits waitcnt (clkfreq / 10 + cnt) 'wait 1/10 second before checking againI think I found the issue. The highdigitpin & lowdigitpin along with Seg0Pin & Seg8Pin are reversed. After swaping places in the Seg0Pin & Seg8Pin, my display is now un jarbled. Now I just have to adjust the high & lowdigitpins to get the order fixed.
Joe
Joe
