Using CNC to mill PCB traces?
Martin Hodge
One can find a lot of videos on youtube showing printed circuit boards being "etched" in home made CNC mills. I watch these and think "Why?!". Is this really a legitimate way to make prototype PCBs? It seems exceedingly "Rube Goldberg" to me. What am I missing?
www.youtube.com/watch?v=bHCCCjdnbQ4
Martin Hodge
webbolts.com
forumexperts.com
Martin Hodge
webbolts.com
forumexperts.com
Martin Hodge
webbolts.com
forumexperts.com
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
I had a Sherline once, retrofitted for CNC work. You have my utmost respect (and sympathy) for engraving PCBs on that equipment!
I do remember this coming up before about your Sherline lacking in the accuracy dept, you now have a nice commercial machine I think - so I am jealous of that.
The biggest challenge I have is lining up the board just right to mill the other side. Once I verify (maybe make small adjustments) that it is milling evenly around the holes, whatever inaccuracies there are, are not apparent. I just walk away and let it do it's thing. So far, every board milled has been useable.
I'm quite happy with my 4 axis CNC Sherline.
Rich H
Signature space for rent!
Send $1 to CannibalRobotics.com.
I think Dremels go up to around 30,000 but yes, it is an option that I have considered. Run out may be more than I'd like but probably not a problem for the boards I am making.
Rich H
Maybe you've tried this for aligning both sides, but here's what I would do: Before milling the first side, drill a rectangular pattern of four 1/8" holes through the edges of the board, in the margins, clear through and about 1/2" into a particleboard substrate. (The substrate has to be fixtured separately from the PCB.) When the first side has been engraved, flip the board over, and secure it through the holes with 1/8" pins or brass rivets. This will ensure accurate registration between the two sides.
This is similar to the technique I use to router proto PCBs from a board house out of panel, except that the alignment holes are designed into the board. The first thing I do is drill the corresponding registration holes in the particleboard, then secure the board using rivets and masking tape. It eliminates having to line up and register the board manually.
