finally, seemingly perfect steering system! pictures of old systems included
It still needs to be cleaned up a bit, painted, wires and wrong types of screws replaced with better ones, and completed welding in some areas but for right now I'm quite excited. After taking 3 forms, finally with a new power wheels motor replacing the old windshield wiper motor it's working like a charm. I just have to decide how to control it--with an expensive motor controller I can't afford or a couple relays and transistors? No duh there. Also included are the different steering forms it took before something finally worked, going in order from oldest to newest.
PG
PG
PS: Nothing wrong with relays! [noparse]:)[/noparse]
PG
Your homebuilt bot and mine just have to team up to take on Parallax' Probots in a head to head, tag team robotic showdown. Your gas engine bot vs their QuadRover· http://www.youtube.com/watch?v=j1GK00oe170· and my poor cousin bot vs their Propeller CNC Bot http://forums.parallax.com/showthread.php?p=869245
I think Pay-Per-View is the way to go. You with me, Pal?
As for pay per view...I think I could handle it [noparse];)[/noparse]
PG
There's a possibility I may try using something like that rod on it, but from what I've seen using wire it seems to bend on the side not being pulled, problematic if using solid rods. I do have cable I plan to replace the wire with later though, so will see if that works first.
Also, I was just checking out my Polaroid 6500 manual. I'm hoping to make sonar object avoidance one of the first programs it runs, so I'll see how it works out. Sometimes I wonder if 35' detection is far enough though, especially before I make the brakes!
PG
