NEW: Motor Controller for Propeller Platform
I've been working on a doggy door for a while - while the software is straightforward, finding a suitable motor controller has been more difficult.
The problem is:
You can find out more, pick it up, download files, etc, on the project page. I also did a pretty detailed howto. And like all the other Prop Platform Modules I've done, layout files are available under the MIT license.
What do you think?
Propeller Forums RSS Feed!
Gadget Gangster - Share your Electronic Projects
The problem is:
- A lot of the inexpensive motor controllers are too meager to control anything but the most dinky motors. ladyada's Arduino shield only does 600mA continuous, 1.1A peak.
- The beefier controllers either:
- are really expensive (Pololu's DMC 01 can do 13 amps, but it's $100), or
- only control a single motor, or
- have complicated control schemes
What do you think?
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler Largos - upcoming nano operating system
John Abshier
@John - thanks for the catch! I've fixed it on the project page and howto.
I did not look at the schematic of the board, but you should make sure that the Propeller pins are completely isolated from a power surge, and maybe a fuse would be appropriate to make sure, if something goes wrong. These are just a few things that I could think of for your platform.
For a real robotics platform, I am starting to think that maybe the Propeller Platform Module (PPM), and the shields may not be the way to go. You can add shields, up or down, to a finite limit, which makes the whole thing look, and function in an awkward manner. For expansion purposes, you really do not have an easy way of adding another PPM, and that is probably what would have to happen as the robot has to use more and more sensors.
I did not want to do a review of the PPM, as it pertains to robotics, IMO, but I hope that you use the critique in a positive way. In general, there is a lack of good quality robotics boards that are cheap, and reliable. I think that a localized cluster of Propellers would probably be a good solution, but, at the moment, there is that lack of boards, and support material. I am NOT an EE, so, I have some severe limitations as to would I could accomplish, form a PCB perspective.
Ray
