Two serial comunication at time
Hi everybody.
Is posible do a double serial comunication whith two PST objects for example?
I need a serial for comunicate whit the PC an the other for a RS485 network.
Thanks.
Jaume Nogues
Barcelona
Spain
Thanks.
Jaume Nogues
Barcelona
Spain
mean you could run 28 serial communications channels if you had enough I/O, which you don't
*Peter*
Tell me more about the RS485 network, what protocols are you using? What are you controlling?
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
I'm learning propeller. I came to BS2 and I want to do a simply home control bus.
I know nothing from protocols and I'm seraching in the forum and Internet.
The structure will be master-slave (of course). First, I think the DMX512 could be a protocol for my idea, but I'm not sure.
Another option is SNAP from HTH, but is dificult for me.
In fact, I'm searching if everybody have made an easy protocol before, for learning it.
Thanks and sorry for my terrible english.
jaume Nogues
Barcelona
Spain
What devices are you trying to control over the RS485/home control bus? Are they commercially available devices? Can you give a link to a device you want to control?
DMX512-A is for lighting, generally, however it can be adapted for controlling other items such as servo or motors or such.
www.tdswieter.com
I want to do all the devices and circuits for me. I don't want use comercial devices.
Could I use the DMX512 for a bidirectional bus (From Master to slave and viceversa)?
Jaume Nogues
Barcelona
Spain
www.tdswieter.com
