Servo Motor CNC Project
Hello Wonderful Folks,
You too Whit (j/k, ha), I have a desire to make a *simple* CNC router using my Boe-Bot.
Does anyone have any suggestions for hardware - getting the servo motors to work with gears, belts/chains, or whatever?
I thought of something totally crude that involved sliding mechanisms used in drawers. I've asked the IT person where I work for some old, unusable printers but he's extremely busy. I also thought of using a long threaded rod w/fabricated nuts that . . . it seems crazy to talk about this, so, I'll just ask for some suggestions rather than prove my mechanical understanding shortcomings.
Thank you,
Scope
Thank you,
Scope
After seeing this video, I'm convinced that anything can be made into a cnc router.
www.youtube.com/watch?v=quN37YskoaM
I have done a lot of thinking about the possibility of making a small cnc mill out of hobby servo's ,but have to finish up some other stuff first.
Brian
"Imagination is more important than knowledge..." Albert Einstein
I don't care about cutting 6061 to within thousandths of inches - I just want to demonstrate a functional model to my students - show them what can be done - and do so w/minimal financial investment. [noparse];)[/noparse]
Thanks - I'm really looking forward to this project - a departure from the excellent books & lessons that come w/all my Parallax systems.
·Here is what you are missing :-)
Brian
Even though you tried to start some trouble above
Steve's ChessBot has a neat, but simple servo and wheel gantry (which he calls it the cart)·to move his robotic arm. I like the wheels running in channels part of the design. The pics and the videos might get some ideas flowing. Check it out.
Good luck and be sure to post back if you get something going.
Whit+
Post Edited (Whit) : 1/22/2010 1:34:21 PM GMT
-dan
Arguing with myself--sometimes me, myself, and I don't always agree.
(Former) Caterpillar product support technician
Here's a quick sketch of what I'm thinking about - using threaded rods supported w/ball bearings inside c-channel - the trolleys (?) are attached to the threaded rod via two nuts and along they go . . . blah, blah, blah . . .
I went through this whole cnc deal about 8 years ago and can tell you from experience that you'll have alot of disapointments if you don't do a little research.
The hobby servo's you are trying to use don't have enough power to pull that big of lead screw ,if you must use treaded rod then go with a small fine tread one (1/4 or so) and the hook directly to it with a hose or somthing, Also they will not provide you with any position feedback.
Just my 2 cents
Brian
I agree with Brian_B·... "The hobby servo's you are trying to use don't have enough power to pull that big of lead screw" ... "if you must use treaded rod then go with a small fine tread one (1/4 or so) and the hook directly" ...· This method will work, but it's not very fast.
Servo Interface to 1/4 inch all-thread:
Next time you are at the·hardware store, look for 1/4 inch inner diameter plumbing·pipe, I think it's for Hot/Cold water lines.· For some reason they keep it·away from the normal plumbing section.· Anyway it only takes a small amount about an inch or so to make a nice interface between a standard continuous rotation servo and 1/4 inch all-thread.· For finer pitch use metric all-thread.· Between the servo and the plumbing pipe I used a small shirt-pin as a cotter pin.· Hint: to drill a very small hole, use a shirt-pin of the same size in a dremel tool.· Between the plumbing pipe and the all-thread use a nut on the all-thread (not shown in picture) to form a 'lock' against the plumbing pipe as to not unwind the·all-thread from the plumbing pipe during operation.····
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 1/24/2010 5:32:48 AM GMT
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
Thanks!
I have a few large - as in gigantic - r/c servos I was thinking about converting to continuous rotation, but it seems like I should figure out what works, and let the experiences of others help shorten my learning curve.
Just curious, has anyone ever converted an Etch a Sketch to CNC?
Happy roboting,
Scope
I like the Etch a Sketch idea. I've been thinking of building one of these flex pickers with 4 servo's and giving a small router.
Here is another link to get the juices flowing.
http://fabathome.org/wiki/index.php?title=Main_Page
I hope some of this info will help.
Brian
Here's just a quick "what if" sketch:
(and yeah, I realize there would have to be holes above the servo horns which would allow attaching the bracket to the servo - I'm lazy)
http://www.mcmaster.com/#
Where did you get those servo's I need to get some that have some power to them
I hope that you do not have to pay and arm leg for them··
··Thanks for any·
Sam
Those servo's are Parallax's continuous rotation servos...
In that particular application I used a metric all-thread that had a pitch of 40 threads per inch allowing me to get away with a lower torque servo motor.
Beau Schwabe
IC Layout Engineer
