Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
CCFL life — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
General Discussion
CCFL life
Chet
150
2010-01-24 01:08
edited 2010-01-24 16:19
in
General Discussion
How long will these CCFL tubes last?
I have an application where they will be lit for about 4 hours a day (roughly 1500 hrs/year)
Chet
Phil Pilgrim (PhiPi)
23,514
2010-01-24 02:44
edited 2010-01-24 02:44
Most laptops use CCFL backlights. If you have any long-term experience with a laptop, that should give you a baseline, at least, for their life expectancy.
P!-Ro
1,189
2010-01-24 03:21
edited 2010-01-24 03:21
In the article I just read it sounds like it should last 25,000 hours, or in your case a little over 16 years, if something else doesn't break first.
http://www.maxim-ic.com/app-notes/index.mvp/id/3528
PG
Chet
150
2010-01-24 16:19
Thanks for the reference Pi Guy. I looks like I can use these and avoid having to change the existing bulbs every three years or so.
Regards
Chet
Sign In
Register
to comment.
PG
Regards
Chet
