Silicone sealant and PCB's
I'm knee deep in mud in the middle of the Great NW working on a Komatsu excavator that has hydraulic control problems. In taking apart the pump computer board, I find that all the leads for all components (processor, resistors, caps, etc.) are sealed with clear silicone sealant. I thought it was common knowledge and an industry standard to avoid using silicone sealant on circuits due the acetic acid corrosion. This excavator is circa 1985. What are your thoughts on this? The mud here is unbelievable, we've had a lot of rain in the last few days!
Kevin
Bad spellers of the world untie!
Kevin
I used it for a UW comms system with great results ..
www.mgchemicals.com/products/silicones/index.html
RTV160...
" The pourable consistency of this product makes it ideal for thin section PCB coating. It is non-corrosive and safe for electronics and metal application. Cures at room temperature."
Peter KG6LSE
"Carpe Ducktum" "seize the tape!!"
peterthethinker.com/tesla/Venom/Venom.html
Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
LOL
How's the acetic-free variety that way then?
dont use normal bathroom sealant, as it is corrosive ( gives off the vinegar smell)
http://uk.farnell.com/dow-corning/2768003/rtv-silicone-3145-clear-90ml/dp/537007
its dow corning 3145, there is a lower viscosity version 3140 which "runs" over the components until it sets.
