GPS Receiver Module and PIC18F2550
Hi!
I am doing my first project with microcontollers and I have PIC18F2550 and a Parallax GPS Module. I really want to ask a basic question of connection between the GPS and the Micro. There are four pins for the GPS: Vdd, GND, /RAW and SIO.
I want to know where to connect the SIO pin. The thing I am confused about is the micro (18f2550) has RX and TX pins (USART or UART??) and most GPS have those. But how would I connect "SIO" to both RX and TX for communication? OR do I just connect it to RX and leave TX?
Also, has anybody done a successful extraction of data after the hardware connection in C? Any exmaples will be helpful. Thanx
Leon
Amateur radio callsign: G1HSM
It may be possible to connect these together without a buffer. It all depends on how you would enable and disable the TX output of the 18F2550. Best in this case would be to use a 1K resistor between the SIO pin of the GPS Module and the RX and TX pins of the 18F2550 to protect against damage from a possible short circuit if SIO and TX are both active at the same time and in opposite states (low / high).
Post Edited (Mike Green) : 1/23/2010 8:45:49 PM GMT
