Reflow soldering boards with components on both sides?
Seems to me with my limited knowledge of soldering techniques that this isn't possible. We are designing a small PCB about the size of a Stamp that has SMD components on both sides, and the number of boards we are going to need ultimately will run around 30. There are one or two skilled hand-solderers on our team, but assembling 30 small boards with components down to 0603 size might be rather too time consuming and error-prone.
What sort of alternatives are there to (expensive) commercial assembly services? We are deciding between purchasing a module that will ALMOST handle our requirements for ~$30 each and adding some extras onto the carrier boards or making our own module, so any assembly cost should hopefully come close to the same price, in volume.
Any suggestions?
Rafael
UC Berkeley '12 EECS
CalSol: Berkeley Solar Car team
www.calsol.berkeley.edu
KJ6AWU
Any suggestions?
Rafael
KJ6AWU
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
Andrew Williams
WBA Consulting
Special Olympics Polar Bear Plunge, Mar 20, 2010
Propeller-Based Reverse Geo-Cache Birthday Present Project
