Stupid question about protoboard prototyping area
They say there are no stupid questions, but I intend to prove them wrong. Here goes.
How are you supposed to use the prototyping area on the various Parallax protoboards? There's a bunch of holes with pads, but none of the pads are connected together. I solder something to a pad, and... what next? How do you make electrical connections?
Prototyping boards with rows of pads connected together, like Gadget Gangster's new ProtoPlus or Bill Henning's Propteus, those I can understand. These boards with isolated pads just baffle me. Help me out. How do you guys use them?
Powered by enthusiasm
But that's what confuses me. There is no hole any more; it's already filled in with the IC leg (or whatever) that I want to connect to!
I design all my layouts on graph paper before I put them down, so a bit of forward planning helps too.
Life may be "too short", but it's the longest thing we ever do.
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
SX Spinning light display·
http://designedbymemicros.blogspot.com/
I don't think this is a stupid question at all. I wondered about it for a long time, until I saw a few photos of people's projects. From the responses, it's pretty clear that there's a wide variety of ways to do this.
I was brand new to all of this when I got my first shipment of Protoboards. I say shipment... because I expected to destroy a lot of them along the way. I had never used a microcontroller, AND I hadn't soldered anything since I was 8 years old... AND I couldn't read a circuit diagram AND everything I did contained some kind of mistake. The last thing I wanted to do was ruin a series of ProtoBoards... but I also wanted something more stable than a breadboard.
So, what I did with the holes was ... ignore them. I think that is a reasonable thing to do. I still use headers with wires to connect my ProtoBoards to generic PCBs, which now contain all of my mistakes[noparse]:)[/noparse] But this ends up with ugly wires going everywhere on my desk and is only a half a step up from a breadboard.
For a full step up... the world had to wait for... Nick McClick.
Nick (of Gadget Gangster) fame has announced a really nice solution to this problem. Take a look http://forums.parallax.com/forums/default.aspx?f=25&m=419352.
Nick's board works with a ProtoBoard.
Rich
@PJ Allen—Wow, that's beautiful! But how did you do it? It looks like the wires are half-wrapped around the pins?
@micro—Did you mean something like PJ's picture?
@Brad—What is this "planning" you speak of?
The pic that Mr. Allen related shows blue insulated, 30 gauge wire soldered to the pins of a device, and then the other ends of the wires are soldered to a flat ribbon cable connector. And yes, the wires are wrapped around the pins to make a good mechanical connection before soldering. To do this requires a wire cutter and wire stripper (both sized to the wire gauge), relatively small needle nose pliers, a soldering iron with a small-ish tip, lots of·light, and a pair of good eyes (magnifying glass comes in handy when you're old).
DJ
Post Edited (davejames) : 1/21/2010 5:07:54 PM GMT
hobby_elec.piclist.com/e_sampl.htm
- Rick
ps. that is not a stupid question. Anyone using a hole-grid style board for the first time would have the same questions.
Andrew Williams
WBA Consulting
Special Olympics Polar Bear Plunge, Mar 20, 2010
Propeller-Based Reverse Geo-Cache Birthday Present Project
But I was pleasantly surprised to find how well the pads worked for holding parts in place.
You do still need to wire the parts together independently from the pad connection; the pads don't help with that, but they were quite helpful for adding mechanical strength to the circuit.
Chris Savage
Parallax Engineering
Check out the new Savage Circuits TV!
Sorry, but I can't sign off on solder-blobbing or much of anything else.· How can you re-work that without getting irritated?
http://www.youtube.com/watch?v=q_Q5s9AhCR0
Ahh yes, one of my many failings. Prior to soldering stuff to a board I actually draw the circuit out by hand to see if what by brain puts on paper agrees with what my brain thinks it actually wants.
Here's a couple of boards I had handy.
The CAR board is one that is in my vehicle at the moment. It has the whole PSU replaced with a combination of 3.3V LDO and a 5V SMPS. It controls the HVAC (replaced a faulty heater valve controller with a servo). Basically at the moment it has an 11 input 10-bit ADC, Servo output, One wire interface and TV output plus soft control of the +5V PSU.
The Proto one is just a USB powered board that I use for general stuff. It has a couple of leds, a Dallas 18B20, 2x16 LCD with PWM controlled LED backlight, 3 pin USB interface, TV, Hope RF 12B radio, SD Socket & DS1307 RTC & 4 hours worth of capacitor backup.
What're those hoop-like things in the lower right corner? Test points?
DJ
And... things not to do -- I dragged the "V_cc" wire over (!) that big GND buss I made there (in "263").· That's not as bad as·it looks because·it's loosely run over and not in contact.
[noparse][[/noparse]I couldn't understand the trouble another member was having, so I put this together quickly for experimenting along.]
to the back side, it's possible to use a standard wire wrap tool and wire.
humanoido
With the Radio Shack boards I make solder globs stick between the copper doughnuts as needed.
That sometimes happens unintentionally though which is bad.
The Propeller Proto Boards must be coated with something that prevents that, because I used resistor leads to
connect all of the holes together that needed to be connected.
VIRAND, If you spent as much time SPINNING as you do Trolling the Forums,
you'd have tons of awesome code to post! (Note to self)
Then I got tired of snipping & stripping THAT many wires, and designed Proteus & Propteus.
- Propteus is the one with the Prop on it
- Proteus is the prototyping board that does not have any pre-defined circuitry, can stack on Propteus (or lots of other boards)
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler Largos - upcoming nano operating system
