SX28DP Burned...Yes, burned like on fire.
I have several of these chips out on projects and I just received one back that looks like the chip caught on fire!· Has anyone had this happen before?
My main question is what might of caused this.· I have the board running off an ATX power supply so the 5v is rated at 30amps.· I have a 1 amp fuse to protect from shorts but it was not blown.
After looking at the design in more detail (I did not lay out the board) , I noticed the inputs do not have a current limiting resistor.· One input goes directly to the 5v through a normally closed switch so it receives a direct 5v.· Is a resistor needed?·If so,·might this be the culprit?
Thanks for any help.
zach·
zach·
please have a look at this thread: http://forums.parallax.com/showthread.php?p=466126
Greetings from Germany,
G
Leon
Amateur radio callsign: G1HSM
