Second LCD to fail
I recently purchased a 4x20 Backlit LCD display from Parallax.
After I opened it up, I configured it for "test" mode and wired it up like so
Imediately random pixels where lit up or half lit up (dim).
I posted on the forum and the general consensus was that the LCD was DOA (dead on arrival).
I emailed Parallax and they sent me a new one under warranty. Thank you Parallax
I wired up the new one and it worked great.
I then wired up the rx pin to p0 on the proto board, set the LCD to 19,2000 baud and started to write code.
I have been using it for about a week or so now with no problems however I turned it on today and the backlight is not comming on and the entire 1st and 3rd rows are lit.
Thinking it was a problem with my code I put the LCD into test mode and the same thing happened. No backlight with 1st and 3rd rows lit.
I have tested the output of the 5v regulator on the proto board with a multimeter and it is at a steady 5v.
Can anyone help me with this? I don't think Parallax will tolerate another warranty request even though I have connected it as per the documentation.
Thank you
"powered by Propeller" domed stickers $1.50 - Find them here
Check out my Design and Technology project for my Higher School Certificate www.ecosureblog.net
LCD Proto Board 5V----------+5V GND--------VSS
Thank you
Parallax Inc.
www.parallax.com
Thank you
This sounds like you may be possibly over writing some value in the controller chip. Although unlikely, it is the only thing that would cause two displays to fail in that short of tome.
The only other thing I know of would be reversing the power.
I can't think of anything else, unless it is an over power issue.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Are you addicted to technology or Micro-controllers..... then checkout the forums at Savage Circuits. Learn to build your own Gizmos!
Checked polarity and it's correct.
One thing I forgot to mention is that the proto board was being powered from a 9V battery and it went flat whilst writing to the display.
Maybe something in the controller chip became scrambled.
P.S. The first display was dead on arrival. This is the first display to actually fail after using it.
Parallax?
Thank you
I have a few questions, that may or may not be pertinent. How do you power up the system with the display on it? Do you have other things on this regulator? Is the display powered with nothing else attached? What is the minimum amount of draw the regulator needs to be active?
I'm wondering if you got a "spike".
James L
James L
Partner/Designer
The 3.3V regulator is powering the propeller chip and related circuitry (crystal, EEPROM, etc) and a RTC chip I purchased from Parallax.
To power it on, I flick the power switch to possition 1.
Thank you
I think the memory on the SX has become scrambled due to the power loss from the 9V battery going flat.
Maybe Parallax needs to add a brownout detector to the LCD board.
I managed to find a 7.2V DC power supply and I will use that from now on (unless we have a blackout).
Thank you
Post Edited (computer guy) : 1/17/2010 12:11:24 AM GMT
I do not think this is a power loss problem. I haven't ever had a LCD go down while communicating with it, but I'm sure the issue would have come up before if that is the case.
James L
James L
Partner/Designer
Power loss is the only thing I can think of, other than a faulty SX chip.
It's 4:30PM on a Saturday so Parallax can't help at the moment and I really need this working.
Chris Savage
Parallax Engineering
Check out the new Savage Circuits TV!
Chris Savage
Maybe it was a spike.
Thank you all for your suggestions.
Thanks for your input though Paul.
Have a new one on the way. Fingers crossed
Now that I have a more reliable power source and a third LCD hopefuly it won't happen again.
This is a first for me and hopefuly a last.
