XBee transmission under water w/ BS2
Wildatheart
I'm currently using Parallax RF transmitters and receivers with Basic Stamp 2's to communicate between·a dock and a floating set of controls consisting of various valves.· The·controls are then·connected via umbilicals to a rather substantial submersible.
Does anyone know from knowledge or from testing if the XBee transmission is·effective through water?
It's a salt water enviornment, and the minimum working depth in water·is about 10 feet - but transmission at 50 feet would be better.
Then, if it is effective, will enclosing the XBee in an aluminum enclosure affect transmission?
Thanks Parallax - looking forward to the XBee BS2 carrier board next month.· I'm curious... will it include a voltage regulator?
I remember that my few watt (I think it was 3 ) " buddy phone" for scuba diving would go across a full pool ...
It used SSB ...
look up OTS they have done some awesome things with UW comms ..
What kind of data rate do you need .. My guess is 600 baud is plenty for a few valves ...
Peter KG6LSE
"Carpe Ducktum" "seize the tape!!"
peterthethinker.com/tesla/Venom/Venom.html
Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
LOL
Everything I find for UW comms is super expensive. Know of anything that's cheap and simple to use?
