Help me think of a better name for this USB charger thingy... — Parallax Forums
W9GFOW9GFO Posts: 4,010
edited 2010-01-24 02:26 in General Discussion
This will be my next Gadget Gangster widget. Tentatively called the "PowerTrip".
It is a USB charger/power supply "thingy".
It features;
Regulated 5V 1amp output. (that's four times as much current as the Minty Boost)
Input 4.8 to 14 VDC
It uses a shottky diode for reverse polarity protection and very low dropout regulator. It drops only .35 volts under a 90 ma load - important when used with a four cell battery pack.
Two pads at the lower right allow use as a breadboard power supply.
The data lines are accessible via two pads above the LED - could double as a USB breakout board.
Uses either a 2.1mm barrel jack or terminal block for power connection. Would like to have a 12v auto plug/cord/2.1mm plug as an available option.
I thought of "PowerTrip" because it provides a way to charge your iPod/etc. while on a trip. Hard to think of a name to call it that describes what it does.
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
Post Edited (W9GFO) : 1/18/2010 8:46:44 AM GMT
    edited 2010-01-18 09:02
    Voltage Input Smoothly Applied = VISA. (It's a charge card, after all. smile.gif )
    edited 2010-01-18 09:40
    @Phil: Plus, it's everywhere you want to go. Be. Charge. Something.
  • edited 2010-01-18 17:57
    UPG = USB Power on-the-go Gadget
  • W9GFOW9GFO Posts: 4,010
    edited 2010-01-19 19:45
    Looks like I've got a couple more days to put the order in.
    V.I.S.A? Clever play on the charge card thing - I think I better not use that though!
    UPG - don't like the acronym but I do like what it stands for. USB Power on-the-go Gadget is quite appropriate and sounds good too, it's just too long.
    Maybe shorten it to PowerGadget USB or USB PowerGadget, perhaps USB on-the-go?
    For six months I've been wondering what to call this thing, gotta make a decision soon...
    Rich H
    edited 2010-01-19 20:07
    Don't visit my new website...
    edited 2010-01-19 20:14
    USBTrip
    I don't care what you call it.. I want one.. [noparse]:)[/noparse]
    OBC
    New to the Propeller?
    edited 2010-01-19 20:51
    USB JouleBox
    USB Juicebox
    Andrew Williams
    WBA Consulting
    Special Olympics Polar Bear Plunge, Mar 20, 2010
    Propeller-Based Reverse Geo-Cache Birthday Present Project
  • Patrick TPatrick T Posts: 6
    edited 2010-01-19 20:53
    USB on-the-go will confuse people with the usb.org version of same name. -Patrick
    edited 2010-01-19 20:55
    PowerTrip sounds good to me. In fact, it's such a good name, I'd do some searching to make sure it hasn't been used already.
  • kf4ixmkf4ixm Posts: 529
    USB Supercharger? Universal Supercharger Board
    edited 2010-01-19 21:08
    ElectricAye said...
    Yeah, good idea. Several times I thought that I should google it but kept forgetting. Guess what? There is already something called the PowerTrip V2. *sigh*
    Rich H
    edited 2010-01-19 21:11
    Maybe I should just stick with what I've been calling it all along - "USB charger thingy"?
    Rich H
    edited 2010-01-19 22:05
    REGULUSBOARD (It hints at "regulate", but Regulus is a twin star in the constellation Leo. You could add a double-star logo to the name.)
    IMPETUSBOARD
    -P.
    Post Edited (Phil Pilgrim (PhiPi)) : 1/20/2010 12:13:51 AM GMT
  • pacmanpacman Posts: 327
    edited 2010-01-19 23:20
    W9GFO said...
    Rich H
    I actually like this name - it's geeky enough and it conveys what it does.
    I would at least browse on over to see what it did if I was visiting the site..Some of the other names I would just think "I don't need a [noparse][[/noparse]fancy/clever/name], so I wouldn't even bother clicking the link".
    But a "thingy", I just might need one of those....
    The future is in our hands.
    Which way to the future?
    edited 2010-01-19 23:43
    W9GFO said...
    Rich H
    Watching the world pass me by, one photon at a time.
  • rjo_rjo_ Posts: 1,825
    edited 2010-01-21 16:16
    usbEE
    emphasizes the quality engineering[noparse]:)[/noparse]
    iPutz
    Shows a sense of humor... understates the utility.
    What I would like you guys to figure out is how to recharge my car battery from an iPod[noparse]:)[/noparse]
  • edited 2010-01-21 18:18
    USB Charger Gadget
  • BradCBradC Posts: 2,601
    edited 2010-01-22 07:07
    Is that using a linear regulator?
    Life may be "too short", but it's the longest thing we ever do.
    edited 2010-01-22 07:34
    Yup, it's a DPAK surface mount.
    Rich H
    edited 2010-01-22 08:49
    W9GFO said...
    Hrm 14V input with 5V @ 1A output. How big is the heatsink ?
  • Jimbo30Jimbo30 Posts: 129
    edited 2010-01-22 17:58
    USB dingy
    Or Dingle.....Like Dongle
    edited 2010-01-22 21:03
    The Curiously Strong Charger...lol
    (from the line on the Altoids box "The Curiously Strong Mint")
    edited 2010-01-24 01:46
    BradC said...
    Well, not big enough apparently. I had tested it at 13.8V and it did get quite warm but nothing alarming. However, I did not test it at the full 1 amp. So today I made up a 5 ohm resistor network and indeed, it goes into shutdown moments after being hooked up. With a 6 volt input it is fine but at 13.8 or 12 volts it just can't shed the heat.
    My milled prototype has about 120 mm^2 of copper that serves as a heatsink, the production version will have about 1,000 mm^2.
    Looks like I might have to de-rate it at higher voltages or limit the max voltage to something lower - or spec it as "up to 1 amp".
    Rich H
    W9GFO said...
    BradC said...
    Yeah, sorry about that. I notice you mentioned the Minty Boost in your first post, and yes this device will supply more current than it will, but then it generates almost no heat.
    At a full load, plugged into a car that is charging nicely ~14.4V your board will dissipate over 9W. I wondered if it would thermally shut itself down or de-solder the regulator first? Sounds like you determined that [noparse]:)[/noparse]
