Weird numbers
I'm trying to communicate with my MCP3208, but all the values that show up on the Debug screen look like weird symbols. I checked that the baud rate in the program and the baud rate on the terminal are the same. I used my oscilloscope to check the data in and out, and the clock and chip select. I calculated the expected value, and the 12 bits that are displayed on the oscilloscope match exactly what I expected(Vin= approx. 2.87V,
·value = 3560, so data in = 110111101000).I'm guessing there is some problem in my program as to reading the data in pin. Here is my program:
CON
ADCclk = 12 ' ADCclk <------<P12
ADCdin = 13 ' ADCdout>------>P13
ADCdout = 14 ' ADCdin <------<P14
ADCcs = 15 ' ADCcs <------<P15
OBJ
Debug : "FullDuplexSerial"
PUB Control | dataIn
Debug.start(31, 30, 0, 115200)
dira[noparse][[/noparse]ADCclk..ADCcs] := %1011
outa[noparse][[/noparse]ADCclk..ADCcs] := %0000
repeat
pulse(ADCcs)
ShiftOut
pulse(ADCclk)
pulse(ADCclk)
dataIn := ShiftIn
waitcnt(1200 + cnt)
debug.dec(dataIn)
debug.str(string(", "))
PRI ShiftIn : dataIn | bitCount
repeat bitCount from 0 to 11
dataIn |= ina[noparse][[/noparse]ADCdin]
pulse(ADCclk)
if bitCount < 11
dataIn <<= 1
return dataIn
PRI ShiftOut | bitCount, mask, dataOut, begin
mask := %1000_0000
dataOut := %0001_1000
begin := 0
repeat bitCount from 0 to 7
if begin == 1
if dataOut & mask
outa[noparse][[/noparse]ADCdout]~~
pulse(ADCclk)
else
pulse(ADCclk)
else
if dataOut & mask
pulse(ADCclk)
begin := 1
else
mask >>= 1
PRI Pulse(pin)
outa[noparse][[/noparse]pin]~~
Assuming you have a 5MHz crystal attached to the Propeller's clock pins, put
at the beginning of your program.
