Motor Torque Calculation?
Hi all,
I'm looking at motors that list some specs, but not all, like torque. I'm trying to figure out how to calculate it. I found some formulas, but feel like I'm missing something.
I'm looking at a scooter motor with these specs: 24VDC, 250W, 3000RPM,·rated at 15A.
Now, it's an electric scooter motor, so I know it must be capable of moving 100 to 200 pounds on a simple geared set up. Eventually, I want to bring it down to about 1000 rpm with a chain and sprocket, and therefore increase the torque. But even with no load, something seems wrong. This is my method and calculation for full load torque, assuming 85% efficiency·(I think full load torque what I need):
HP = V x I x Eff·· =·· 24 x 15 x .85·· =· 306·· =· .410
············· 746······················· 746···············746
T = HP x 5252· =· .410 x 5252· =· 2153· =· .71 ft-lbds
··········· rpm···················· 3000·········· 3000
I must be doing something wrong, or using the wrong calculatioin. Because the torque cannot possibly be under 1 foot-pound!? Can it?
Thanks!
John
Post Edited (JohnBot115) : 1/14/2010 8:32:03 PM GMT
Thanks!
John
by the way: [noparse][[/noparse]adimensional] != [noparse][[/noparse]ft*lbf], include the units on your formula or it is meaningless.
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
If you gear for 1000 rpm at the output shaft (and motor at 3000 rpm), the torque goes up but the HP remains the same. You'll get about 2 ft-lbs at the output shaft.
The only reason small motors can do the things we ask of them is they have the ability to operate under overload for some period of time before burning up. So, your 250 W motor may actually be able to draw 30 or 40 amps for
some minutes to get the load moving, or accelerate or go up a hill.
As we used to say about car racing............there's really no substitute for cubic inches! If you need more power, start with a bigger motor.
Cheers,
Tom Sisk
http://www.siskconsult.com
I built an e-bike with parts from TNC scooters·that turned out quite nice, here's a video. I used a 250W gearmotor, which has internal gearing and·comes with a·final output sprocket that takes standard 1/2" bike chain, easy to find at any bike shop, even hardware store. I recommend this over non-geared motors·sprocketed for smaller #25 chain that is harder to locate.
I've posted previously to·recommend using electric bike parts in robots. Cheap, strong and plentiful. Controllers are designed for hall-effect throttles, so they might require some hacking, I haven't tried that yet.
Is 50% efficiency a reality in this case? It seems a little low to me. Considering the motor is sized correctly.
Post Edited (AJM) : 1/17/2010 6:10:02 AM GMT
http://www.micromo.com/n390432/n.html·has good DC motor info.
